What have i done !!!!
Brianc
Postby Brianc » 27 Mar 2019 18:28
Started my replace dash project today - and i have really struggled!!!
I cant get the steering wheel off - so its the three leg puller tomorrow!!!
Got the seats out and all the centre console off eventually - found some very debatable wiring underneath the console!!! In fact some seems to have burnt out.
Also found that the 'drain bungs' in the floor have gone through
It seems that you cant take the instrument panel out before you remove the dash ????
Tomorrow is a fresh day
darrellw
Re: What have i done !!!!
Postby darrellw » 27 Mar 2019 19:51
Brianc wrote:It seems that you cant take the instrument panel out before you remove the dash ????
You need to take the top section over the instrument cluster out to remove it, but not the entire dash.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Brianc
Postby Brianc » 27 Mar 2019 20:22
How do you get it out - upwards?
I cant see how it comes out ?
Postby saabfast » 27 Mar 2019 20:25
As above, take the top section off, reach under and release the speedo cable, take the weird screws out of the top of the instrument Perspex and slide it up and out. The instrument panel will then ease forward to allow the wiring plugs to be removed and the panel taken out.
Postby stevie_a » 27 Mar 2019 20:40
Brianc
Postby Brianc » 27 Mar 2019 20:54
Looks like mine !!!!!
Postby Beans » 28 Mar 2019 18:36
Brianc wrote: ... I cant get the steering wheel off ...
Never needed a puller! Loosen nut but leave it on the shaft .
Give the rim a few blows with your hand (spread around the rim)
Than try to wriggle the wheel of the shaft (the nut is there to prevent the wheel from smashing your face)
You might need some penetrating oil and a few more blows to both front and rear of the steering wheel.
Postby Beans » 28 Mar 2019 18:38
Brianc wrote: ... How do you get it out ...
Don't forget the two screws at the bottom of the dash
Postby Cobber » 29 Mar 2019 03:20
If a steeing wheel is too stubborn to remove with the belt the rim with you hands method, I've found the best puller is a small crows foot type, used on harmonic ballancers
You may need to source some bolts of the correct length and thread, to suit the wheel.
Bacic harmonic balencer pullers can be purchased on online (fleabay etc) for a very modest outlay.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Postby Hasbeen » 29 Mar 2019 10:05
The easiest way to remove a steering wheel is.
1/. Get a willing helper, a brass drift & a hammer, or plastic faced hammer.
2/. Undo the nut, & screw it to the top of the shaft. Set it up exactly level with the top of the thread.
3/.Sit in the seat, & apply upward pressure on the wheel.
4/. Have your helper hit, or really lightly tap the top of the steering shaft downwards towards the rack. The wheel will pop off.
If you are dextrous or can't find a willing helper, prepare the shaft & nut. Sit in the car applying upward pressure on the wheel with your thighs/knees. Tap the top of the shaft as before.
NOTE; You are not trying to bash the steering shaft out the other side of the rack, a soft tap is usually enough.
I couldn't count the number of wheels I removed this way from cars when I had my steering & suspension shop. None ever offered much resistance.
Postby FI Spyder » 29 Mar 2019 14:31
I used a white rubber mallet (also useful to tap paint can lids back on) to tap the back of the wheel to loosen it (nut still on). Came off easy. Mind you that's on a Sacramento car were fasteners are almost new looking so not really representative of most cars.
Users browsing this forum: Google [Bot] and 52 guests
