K&N air filters
William Moore
K&N air filters
Postby William Moore » 29 Aug 2017 18:20
I was thinking about fitting some K&N air filters to my TR7 2.0 L and l was wondering if you would need to change the jetting on the carbs?
Re: K&N air filters
Postby Rich K » 29 Aug 2017 18:30
Hi, you will need to change to richer needles as the K&N filters allow more air to enter the carbs than the restrictive standard air filter. The jets do not need changing as it is the shape and profile of the needles that dictate the amount of fuel that is metered into the carbs.
My 2 litre has BAL needles to complement the deep K&Ns along with an extractor exhaust manifold and sports exhaust system. I believe that this is the usual recommendation for this combination. I am not sure what needles would be needed if you are only adding the K&N filters.
Rich.
Re: K&N air filters
Postby UKPhilTR7 » 30 Aug 2017 03:38
After reading this up a bit, it is also my understanding that if you have k&n air filters on you need to up-rate your needles to BAl and you need a sports exhaust manifold system.
Re: K&N air filters
Postby Hasbeen » 30 Aug 2017 08:00
While you will gain more from improving your exhaust at the same time as you improve your inlet breathing, most of the increase in power comes from the inlet side, & is a really worth while improvement.
I don't use K&N filters, I use Ram Flow, which are about equivalent, with BAL needles, & the response was more than I expected.
William Moore
Re: K&N air filters
Postby William Moore » 30 Aug 2017 16:48
Thanks for the help guys now just need to get some money together and get on with purchasing the items. :D
simps
Re: K&N air filters
Postby simps » 30 Aug 2017 21:56
The needles are reasonably priced. Its the filters that cost more than you'd think.
Re: K&N air filters
Postby UKPhilTR7 » 30 Aug 2017 22:36
If it came to it you could do it in stages. I got a price check from Robsport for BAL needles and they came in at just over £11 each. My car currently has the filters and the exhaust but not the needles and she still moves :D
Re: K&N air filters
Postby Hasbeen » 31 Aug 2017 09:57
Your filters must be full of dirt Phil, you drive gently at low revs, or you have the BAL needles.
With free flowing filters & standard needles the thing will go into fuel starvation a bit under 4000 RPM.
Re: K&N air filters
Postby UKPhilTR7 » 31 Aug 2017 12:28
Mmmm that has me thinking Hasbeen. I have not taken the cars apart to see if I have BAL needles. I just thought that I had normal as I put the k& n filters on.
simps
Re: K&N air filters
Postby simps » 31 Aug 2017 19:33
I agree. Without the needles it will feel dead flat above 4000 rpm
It's an easy check, just a flat screwdriver required. Replacement is also very easy
Re: K&N air filters
Postby UKPhilTR7 » 31 Aug 2017 22:18
Cheers guys, it has got me thinking now about it. I will have to have a look the weekend.
Re: K&N air filters
Postby Hasbeen » 01 Sep 2017 01:26
I have never run a 7 with BAL needles & a restrictive air filter.
I should do it some time, as an experiment, to find out how it runs, & how the performance is effected.
John_C
Re: K&N air filters
Postby John_C » 01 Sep 2017 11:17
Short of changing the camshaft to a higher lift item I think the best thing you can do to a TR7 is to remove the original fan and the whole pulley assembly and stick an electric on. K&N air filters might not do a darned thing other than affect cold running... badly.
www.triumphdvd.co.uk
Re: K&N air filters
Postby Beans » 01 Sep 2017 11:39
John_C wrote: .. K&N air filters might not do a darned thing other than affect cold running... badly.
Depends were you locate them!
http://tr7beans.blogspot.nl/2015/04/cool-air-and-noise-reduction-part-2.html
sonscar
Re: K&N air filters
Postby sonscar » 01 Sep 2017 11:51
After fitting KN filters on previous cars and finding it affected the performance badly I tend to stay away from them.I would like to see some "scientific" analysis of the air/fuel mixture before and after fitting and adjusting things.Note I am not saying good results are not achievable.I have some injected cars with datalogging and fitting a new "standard" exhaust system affected the driveability noticeably,confirmed by the datalogs showing greater fuel mixture adjustment.Just my thoughts,Steve
Users browsing this forum: No registered users and 160 guests
