tonneau cover..rusty stiff zip
bonnietiler
Postby bonnietiler » 02 Sep 2016 16:11
I have been given 2 tonneau covers for a TR7 but they have been in a damp garage the zips are a little corroded and very stiff..is there a cunning ruse, or are they for the municipal tip?
Bonnietiler
Re: tonneau cover..rusty stiff zip
Postby saabfast » 02 Sep 2016 17:08
Suggest spraying the zips with WD 40 and easing them carefully along until running free, wiping clean, then using silicon spray/grease on them.
dmtrmp6
Postby dmtrmp6 » 03 Sep 2016 02:40
By all means use a liquid/spray product to help get the zip free, but once this is achieved and the zip is essentially free from the corrosion, you are better off cleaning off the liquid and using a dry lubricant, either a spray lubricant that drys on application (maybe a garage door lubricant) or a dry stick based lubricant.
A simple, cheap trick from previous years is to give the zipper teeth a really good coating of wax, ie rub a candle along the length of the zipper face and work the zip closer back and forth to distribute the wax. If you use a wet lubricant you will attract dust etc and the zipper will eventually clog/bind up again. Rgds, DM
Howard722
Postby Howard722 » 03 Sep 2016 08:28
If these tonneaus are `new` to you and your car has not had a full tonneau in use/fitted before you will need the button fixes along door tops, top of dash etc. (and header rail if they are of the the vertical `screen closing` panel style). All do-able but worth considering in your decision making. :?:
Enjoy & regards
Postby Cobber » 03 Sep 2016 10:52
It shouldn't be a big job to replace the zip for an motor trimmer, sail maker, upholsterer etc.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
