Hi all,
there's a piece in the mag about KDU487N and it mentions the works V8's had 4 valve cylinder heads, is this true?
Thanks
busheytrader wrote:That's the first I've heard of that. I'm no expert but the RV8 is an ohv design and how would you adapt that to work 4 valves per cylinder?
Hasbeen wrote:It was a single overhead cam, with no combustion chamber in the head. The valve seat inserts were level with the bottom face of the cylinder head, & the entire combustion chamber was formed in the piston. When you put the head down, face down on a bench, it was sitting on the valve heads.
Users browsing this forum: No registered users and 66 guests
