Kenlowe fan wiring
macmattom
Kenlowe fan wiring
Postby macmattom » 05 Jun 2009 16:03
<font face="Comic Sans MS"><font size="2"><font color="blue">I have replaced my fan with a Kenlowe unit and was wondering if I need to wire the control unit in with a relay, or can it go directly to the battery?
Also, I'm not sure of the current these things draw, so does anybody know the rating of fuse I should use, which I will place in the +ve line from the battery to the control unit (unless any of you know differently!).
Is it worth wiring in an over-ride switch in the cockpit?
A simple wiring diagram would be really appreciated.
Mac
</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby jclay (RIP 2018) » 05 Jun 2009 17:40
Yes,
Wire it to a relay with the temp sensor on the radiator, that is how the original fans were wired with A/C. I have an override switch on the side of my heater cover so I can turn the fans on at will.
Postby bmcecosse » 05 Jun 2009 21:23
Yes - you should wire it through a relay and a 20 amp fuse on the main feed to the relay (not the sensor cable!). I can't believe at the price they charge for these fans - they don't supply fuse/relay/wiring diagram etc with the fan ??
macmattom
Postby macmattom » 05 Jun 2009 21:50
<font face="Comic Sans MS"><font size="2"><font color="blue">To be fair to Kenlowe, it came fitted to a car so they didn't actually charge me for this. However, the reason I wouldn't buy one direct is exactly that - they are very expensive!
This might sound really stupid, but does anybody out there have a wiring diagram to direct me how to wire the unit in? The car it came from didn't have a relay, just straight from the battery; that's why I thought it didn't need a relay.
Thanks for the advice already, please keep it coming.
Mac
Postby bmcecosse » 06 Jun 2009 09:00
Basic relay has 4 connections - it's an electrically operated power switch. Two of them operate the coil that works the internal switch - these should be connected to the sensor arrangements - or the 'by-pass' switch, and earth. The other two are the ones that switch the high current to the fan - so one to the fuse - and then from the fuse to the brown wire (battery +ve) somewhere convenient on the car - and the other to the fan, which will of course need to be earthed. If you get a relay - it should come with details of what the various connections are for.
Sorry - I'm useless at drawing diagrams - but I'm sure someone will be along soon who has that skill!
Here's a very useful guide I found ! http://www.r1200gs.info/howto/relay.html
Postby UKPhilTR7 » 07 Jun 2009 00:06
I have just fitted one myself and finally got it working a treat. I will scan the diagram if you want and send it to you.
I put a 30 amp fuse in mine to be on the safe side and I am yet to fit the manual override switch, but I think it will be worth it
macmattom
Postby macmattom » 07 Jun 2009 11:13
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by UKPhilTR7</i>
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">That would be a great help thanks, I'd really appreciate that.
Mac
Postby UKPhilTR7 » 07 Jun 2009 20:27
I have not had chance to copy my instructions, but have found this on the net. It is the same as mine, but with the exception of the manual override switch. Hope this helps:
http://www.holden.co.uk/productimagesWD/080_257.jpg
macmattom
Postby macmattom » 07 Jun 2009 21:52
<font face="Comic Sans MS"><font size="2"><font color="blue">Phil, thanks very much for the link. I now just have to find a diagram for wiring the fan in through a relay - I have found one on the net that says terminal 85 goes to earth but the one I have bought has a wiring diagram on the back which shows terminal 86 going to earth!!! Confused, I am.
Cheers again,
ngtf
Postby ngtf » 07 Jun 2009 22:17
Hey Mac, hope this helps a little. It's how Dad wired mine.
Gavin
Eeyore rides again !!
EOR14W - Persian Aqua 2L Dhc, Now rebuilt and looking lovely - Sprint engine now fitted!
Postby bmcecosse » 07 Jun 2009 22:38
Be aware that 'Phil' said he wired his fan directly into the radio feed! This is not wise - the ignition switch will not stand the load for long. The main power should come directly from the battery +ve (brown wire) - and only the signal wire for the relay should go through Ign - to prevent the fan running when the Ign is OFF!
Postby UKPhilTR7 » 08 Jun 2009 08:49
[quote]<i>Originally posted by bmcecosse</i>
<b><font color="red">Where on this post does it say that???!!!</font id="red"></b>
Rust Restorer
Postby Rust Restorer » 10 Jun 2009 20:47
Image Taken from my website, Guaranteed to work as I have 2 cars wired like this.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ngtf</i>
Gavin
1980 DHC Cashmere Gold
1981 FHC Persian Aqua Blue
www.andys-tr7.co.uk
http://andystr7blog.blogspot.com
ngtf
Postby ngtf » 10 Jun 2009 20:57
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rust Restorer</i>
Image Taken from my website, Guaranteed to work as I have 2 cars wired like this.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Hi Andy, no malice intended. If I had known the owner I would have given credit where it's due. I just new Dad used this to wire mine and thought it would help Mac.
All the best
Gavin
Postby bmcecosse » 10 Jun 2009 22:54
Phil - to quote from your thread about wiring up your fan - "<font color="blue"> Finally got around to finishing all the wires today to my new fan and got it working all good. In the end I have tapped into the ignition wire that feeds the radio and feeding the cable through the bulkhead with the main wires (loom)". </font id="blue">
Despite advice to use a relay, brown wire feed, fuse etc - you decided the radio feed was the one to use ! It is likely to fry the ignition switch - which was never designed for those loads. I gave up offering advice in your thread because you seemed to just ignore anything that was said - despite it being offered with best intentions.
Users browsing this forum: No registered users and 103 guests
