Petrol tank replacement
Postby john » 31 May 2009 18:41
okie dokie then it's got to be done so i'm going in any advice before i start......
Postby Underdog » 31 May 2009 19:02
Start soaking all the fasteners with rust penetrant. I've had my rear axle in & out so many times it doesn't seem much of a chore. Of course having an air wrench makes a huge difference.[:D]
Postby john 215 » 31 May 2009 20:20
As well as the tank, get new straps, with rubbers and studs, new sender, with seal and locking, new fuel hose. Run the tank down on fuel as low as you can as you dont want to put the old fuel in a new tank and lifting a half full tank out is not the one either!!!
Good luck, not actually that bad a job, the first 6 you do are [:p]
Steve @ SandS
Postby Steve @ SandS » 31 May 2009 21:18
It's the next 300 or so that are more difficult [:D][:D][:D]
Steve @ S&S Preparations
Postby Hasbeen » 31 May 2009 23:07
Fit lock nuts to the top of the strap studs, inside the car.
Two in the boot front bulkhead, & two behind the seats, in the back
cabin bulkhead.
Without these fitter, the studs screw out, when you try to remove
the strap nuts, making things difficult, by winding the straps up
into a pretzel.
Jolyon39
Postby Jolyon39 » 01 Jun 2009 02:37
Hasbeens method is the way to go.
The studs for the tank straps protrude into the car through the captive nuts they are mounted in. A lock nut on this protrusion makes it an easy task. Well, easy compared to the alternative. Use a wire brush and lots of penetrant too, those threads under the car will be a real mess.
Postby busheytrader » 01 Jun 2009 09:34
Hi John,
My tank emptied itself of fuel without any help from me......
All above is good advice, my tank straps were mangled in the removal process and the rubber cushions had rotted so budget on new items. My sender was in A1 condition so fitted a new seal and refitted it. In hindsight a new one would have made sense.
Robsport recommended coating the outside of the tank in Waxoyl to protect the outside from corrosion. Refitting it was a bit like juggling a slippery pig afterwards. It would have been better to coat the top half in Waxoyl and only where the straps fit on the bottom half. This enables you to grip the bottom corners to move the tank around, then Waxoyl the rest afterwards. The rubbers have been known to trap water and rust the tank from the outside.
Spray lots of rust penetrator on the nuts / bolts well before you start work on removing the tank, axle and exhaust. Reassemble with lots of copperease / coppaslip in the appropriate places etc. to make things easier to undo next time. (10 years after fitting a recon rear axle I had to drop it for the tank replacement. Having used copper grease previously it was a doddle)
Whilst the tank is out, stick your head and a torch up there and clear out all the mud / grit with strong brushes, look for rust to treat and apply more wax. There are some beautiful rust traps around the chassis rails that you can't see otherwise. I've heard that after 30 odd years this is the next MOT weak spot on our cars.
Wear an old cap to keep all the crap and waxoyl out of the hair. Otherwise "simples".
Postby john 215 » 01 Jun 2009 17:41
Hi Adam,
I done the same as you, painted the top in Waxoyl and then got covered in it whilst refiting it [V] if that stuff sticks to metal like it does skin then we have nothing to worry about!!! If you have a roll over bar to fit to a DHC or plan too, with the tank removed is the ideal time to do so, as you can get to all the bolts to fit nuts, normaly the N/S is hidden by the tank!
pupinabox
Postby pupinabox » 01 Jun 2009 18:49
How 'bout taking some pictures as you go to help out us amatuers[:p]
Postby busheytrader » 01 Jun 2009 19:58
Too high on Waxoyl to grip anything, not even a slippery camera.......
frankman
Postby frankman » 01 Jun 2009 20:32
poor guy I saw it a few months made ...[B)]
You need to take one Spring and one Damper (Shock absorbers) out (Driver side US+Euro)
good lock and a lot of WD40 or anti Rust [}:)]
Hello from Switzerland
Frank
Postby windy one » 02 Jun 2009 15:30
On rusty nutz, bolts, screws...whatever, I use a chemical (Ive found) far better than WD40. Its called 'PB- Blaster'. Made in Cleveland Ohio, they call it a 'concentrated copolymer penetrant'.
I have gotten even the nastiest rusted bolts free with this stuff, far faster than WD40. It smells and its odor lasts a while unless you really clean it up afterwards, but the stuff is incredible.
www.blasterproducts.com (no, Im not an employee or stock holder of the company, just want to share info on products I find to work the best)
Postby john » 02 Jun 2009 15:59
ready to roll lads suspension dropped couldn't get the damn exhuast to part company with the centre box so i've pushed that to one side,after releasing it from the other end of the manifold and as i guessed and you've confirmed the LH shock needs completly removing. most of the nuts gave way without too much trouble just need rick to tell me the tanks in so i can go and collect it.
oh and me to remove the old tank tonight
so far so good
in the meantime i'll give the area it a good rub down/wire brush and paint all i can see...
TR7Aaron
Postby TR7Aaron » 02 Jun 2009 18:49
I'll give a second vote for PB Blaster. It's outstanding!
Aaron
Postby john » 03 Jun 2009 08:52
She's out easier than i thought,
what did make it a lot easier was disconnecting the hand brake and brake lines from the body as show above, i could then drop the rear axle a lot lower to wiggle the tank out.
only real bug was the petrol filler cap, the nuts being well rusted in on that, but otherwise a lot easier than i thought it would be
Users browsing this forum: No registered users and 97 guests
