head bolt Torque
Randy
head bolt Torque
Postby Randy » 29 May 2009 13:38
Can anyone tell me what the required torque is for the head bolt / nuts on a '76 TR7?
Postby bmcecosse » 29 May 2009 13:50
Says 50 ft lbf in the Haynes! Make sure the threads are clean and lightly oiled.
Postby Workshop Help » 29 May 2009 15:16
Noooo. In Section 06-1 of the 1976 Triumph TR7 Repair Operation Manual, Part No. RTC 9200, the factory specified torque setting for the Cylinder Head to Block is 55 lbf ft, or 75Nm, or 7,6 kgf m. To use less than the specified amount is to court leakage. Be sure and follow the correct sequence pattern when torqueing them down.
We have several of the Haynes manuals in the library and have come to consider them as not all that reliable. One local sage remarked they contain just enough information to get you in trouble. In the case of the 1997 Ford F-150 pickup electric window motors, the Haynes manuals lack of relevant information almost cost me the tip of a finger. We are not going to say they have only the value of used toilet paper, but we will opine one should obtain the factory publications and study them for any repair project one has in mind.
tr7sprint1
Postby tr7sprint1 » 29 May 2009 15:58
the torque and torque sequence has change since that tr7 ROM in a couple of technical service bulletins (the headgasket also changed). I'll look it up and post later tonight. i do agree with you on the Haynes manuals.
Postby Beans » 29 May 2009 16:46
Torque sequence in the Haynes manual is correct (it corresponds with the later (1981) BL workshop manual)
Start with the middle bolt followed by the middle stud and work outwards in the same sequence starting right of the middle,.
Postby FI Spyder » 29 May 2009 20:03
1980 manual says 50ft/lb. Don't forget to retorque every 500 miles for the next few 500 miles. Haynes are better than nothing. 'nuff said.
Postby bmcecosse » 29 May 2009 20:12
I think for the size of studs/bolts - that 50 ft lbf is more than enough! 55 may just get you a snapped stud! But use your own judgment!!!!!!!!!!
Postby Beans » 30 May 2009 00:07
Dunno ... mine are torqued down to 95 Nm and they didn't snap [:I]
Users browsing this forum: No registered users and 80 guests
