Replacing the gearbox bushes.
Postby busheytrader » 17 May 2009 14:53
I dropped the propshaft so a recon shop can have a look at it as it may be out of balance.
Whilst underneath the car I looked up at the remains of the rubber bushes that hold on the remote extension. Apart from needing lots of extra thin hands I eventully replaced the bushes with the housing in situ. All was fine until I stirred the gearstick to find it stuck, nothing moving.
Even though I was careful not to move the housing about much, the extension shaft had still managed to drop off the selector shaft's pin at the back off the box.
http://www.roversd1.nl/sd1web/index.html This useful link from one of Mildred's posts has the guy's right thumb over the offending ball joint.
I ended up stripping off the gearstick topside and removing all the new bushes so I could engage the pin again. I lost a good few hours as I found my way through this. Hopefully you won't make the same mistake.
Postby Beans » 17 May 2009 15:15
...Hopefully you won't make the same mistake...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Happened to me last year while replacing the infamous bushes.
But as the extension shaft fell out pretty easily I thought it would go back in easily, And it did [:)]
