INDICATORS FLASH TO QUICKLY
Postby tr7inc » 07 Apr 2009 21:14
Hi guys just posting on behalf of a another member whos PC has given up the ghost, he txt and asked me if i could ask you guys this question, when he took his car for its M.O.T they said his indicators where flashing too fast, any ideas, could it be a faulty earth for connection at a first thought?
Many thanks all
1979 Pre Production Prototype Inca Yellow DHC
Postby Workshop Help » 07 Apr 2009 21:22
Without knowing what kind of vehicle we're dealing with, a first guess is either a burned out bulb, or a defective flasher unit.
Postby busheytrader » 07 Apr 2009 21:23
They're usually too slow for the MOT, not too fast. Corrosion in the connectors and bulbholders slows them down.
Postby tr7inc » 07 Apr 2009 21:33
Mildred TR7, ohh and Adam i thought the same as you, but he says def faster, could it make a difference if the front side repeater lamps werent in situ, just the blanking plates?
tom bauer
Postby tom bauer » 07 Apr 2009 22:10
assuming this is a tr, the flashers use the current of the bulbs to heat a bi-metal strip which then bends and opens the circuit. when it cools the contacts close and the cycle begins again. so there are several possibilities, wrong or defective flasher unit, wrong bulbs i.e. too high wattage, a grounded or partially grounded wire. since the hazard circuit uses a seperate flasher unit, turn them on and see if it flashes at the correct rate. if it flashes too rapidly both left and right i would suspect the flasher unit first.
tom
Postby tr7inc » 07 Apr 2009 22:20
Many thanks Tom, will advise
moestr7v8
Postby moestr7v8 » 08 Apr 2009 00:34
Hi Steve
I would advise changing the flasher unit to an electronic one much better and more reliable.
Regards
Moe
Postby PeterTR7V8 » 08 Apr 2009 01:18
Indicators will sometimes flash quickly if a bulb is blown but I'm guessing the tester would've looked at both ends of the car before coming to his conclusion.
Postby gaz » 08 Apr 2009 06:18
testers over here can be funny beggers and that may have have involved walking from one end of the car to the other i once had a car fail on the seat belt missing windscreen washer not working..........
how much would it have taken to put his hand down the back of the seat and pull the lap strap out and put a drop of water in the washer bottle instead he had to do a re test.........
Postby tr7inc » 08 Apr 2009 06:38
Hi Peter, yes Dave told me that they supposily tested the unit, but to be truthful it seems each time he brings thr car back from this garage & after he works through the M.O.T fail sheet they spot another fault, different day, different tester i quess, i personally think they are given hem the runaround, thats what i txted and told him, hi Gaz yes that point you made ohhhhhh so true! Many thanks i will pas it on to him Peter about the electronic flasher system.
Postby busheytrader » 09 Apr 2009 09:49
I use the MOT garage just down the road from where Robsport used to be. It's a 40 mile round trip but it's mostly country roads and nice when the sun's shining.
Why do I go there. Well funilly enough they're very used to 7's and ensure that the engine's running when testing the indicators, otherwise they might not run fast enough.
wedggie perrin
Postby wedggie perrin » 09 Apr 2009 11:05
Yes I use the same garage as Robsport, because they see more TR7's than most and they know what they are doing. Take it to some spotty herbert in Halfrauds etc and they have never seen a TR7 before.
nofinchance
Postby nofinchance » 11 Apr 2009 12:30
Kinda off topic but I had terrible trouble with my old capri's indicaters.They would jam as if thinking before another flash.This happened rarely but annoyed me so I changed the flasher unit.[:(!]Big trouble[:(!]. I must have had the car that the handbooks refer to as 'some models use this varient' Cuz the indicaters worked fine but the dash green light refused to work.Turns out I needed a flasher unit with one terminal different to the 100's out there that everyone else uses[:p].
As for MOT stations some are a bit over zealous. I think some find faults so they can put on the sales pitch telling you "we can mend that madam ,only and arm and a leg +VAT" I used to use a guy who every year messed up the carb because he said the emmissions were out.Then he would try and sell me a tune up! I only fell for that once and now use a Land Rover dealer as he MOTs anything but will only work on land Rovers.Oh and once a garage tried to fail my MK2 1977 capri because the fog lights did,nt work.HELLO THEY WERE NEVER EVER FITTED FROM NEW.Now I may be blonde but I ain't that daft[:X]
Postby busheytrader » 11 Apr 2009 14:11
Agree with you there. I know MOT's and scheduled services are meant to find things before they go wrong but there are some places that try it on, especially with female owners.
At one garage my sister took her car in for a service and MOT, they advised her to replace tyres that were down to their last 5mm and replace coolant and brake fluid that they'd only changed last year. They hoped she hadn't a clue.......
Postby nervousnewowner » 12 Apr 2009 18:34
cheers for posting for me steve, and yes guys it was for my tr.... thats why asked steve to post on the tr forum,,,lol... and fiddling around on weekend and seems to be cured now, looks like was bad earth causing it, new flasher unit no diff, changed hazard switch no diff. fiddled at back and bingo, just hope it lasts til mot....
