how to adust spax
samco
how to adust spax
Postby samco » 05 Apr 2009 07:12
I've got spax adjustables on he rear of my wedge and when it went on the road I fully unwound the adjusters to make them as soft as possible to allow the car to settle on its new poly bushes. How may turns of adjustment are there on these adjusters and what would you reccommend for fast road use :-)
Check out my album
Postby Chris Turner » 05 Apr 2009 07:30
Adjust them 1/2 turn at a time until you find the setting that suits.
www.triumphtrs.co.uk
TR8 FHC
TR7V8 rally car
Postby busheytrader » 05 Apr 2009 07:31
I've got the same on the rear of mine. There should be 12 clicks of adjustment, each click roughly 1/2 to 3/4 of a turn.
Most drivers prefer the Spax about 2 - 4 clicks away from minimum, mine are on setting 2 as I like my fillings to stay in my teeth. With your screwdriver, unwind the adjusters fully anticlockwise, you should feel when they come to the end of the adjustment. Then wind gently clockwise and you should feel it click into each setting.
I went up to 6 once and felt every ripple on the road. Probably great for a track day but not our pot holed roads.
Postby busheytrader » 06 Apr 2009 15:43
Hi Samco,
Did it work for you?
