weather seal
nofinchance
weather seal
Postby nofinchance » 03 Apr 2009 18:58
I have to replace my drivers door weather seal as the door does not have one at all[:0].I have the seal and the clips but see from previous posts that I need a 'special tool ' to aid fitting.I am thinking it is the kinda thing you only need once so does anyone have a 'one careful owner'[:D]used one I can buy,or loan or something? If not it's broken finger nails and very unlady like language coming from my garage.[:(!]
Postby windy one » 03 Apr 2009 19:00
Which seal....the one that seals the door to the unibody, or the ones that seal the window-channel on the door?
Postby john 215 » 03 Apr 2009 20:06
Hi Steph,
I got one, can post it to you if you cant find anyone local, PM me your address, you can do the job without it but this make a piece of p [;)]
Not sure about the careful owner but still works, you place the clip in the bottom section and then whilst holding the seal down with one hand pull the clip on using the tool with the other hand. Apprently modelled on what thet used on the prodution line.
Cheers John.
Postby FI Spyder » 03 Apr 2009 21:18
If the door card is off anyway to clean and grease the window winder, paint the 1/4 window frame, clean and grease the door lock, replace window channels, clean up any rust in lower door area, waxoil bottom part of door or what ever, with the window out the clips are easily pushed up by hand into position. If the waist seal is gone it's probably time to take the stuff out of the door and clean/grease/replace stuff anyway. I did it that way to my Spider and will have to do it to my TCT. If your going to have to do part of it you may as well do it all, do it right and forget about it for next 30 years.
nofinchance
Postby nofinchance » 04 Apr 2009 07:42
Hi john,I think it was you who told me about the need for a fitting tool.If I could borrow it that would be great[:D] I will return it after use.I will pm you my address.So it is the exact item used on the production line [:0] no wonder they were always on strike! nuff said [:D].
Mr Spyder.I am with you on the do it 'belt and braces' I have already waxoiled the bonnet,boot and sills as the carpet was up for rust hunting.I sprayed a little through the gap made from the missing widow seal into the door[:o)].I will do a proper job when the door card is off.
Users browsing this forum: No registered users and 30 guests
