clutch
den1560
clutch
Postby den1560 » 15 Mar 2009 17:32
having problems with my clutch will not go into gear only if i raise the back end is this an air lock , and how do i solve the problem 'as soon as i drop the car back down no clutch again please help den
tom bauer
Postby tom bauer » 15 Mar 2009 18:12
does the pedal 'feel right'? you could need bleeding, have some broken linkage issue, or have a worn out clutch.
Postby bmcecosse » 15 Mar 2009 18:56
When you say 'raise the backend' - is this to allow the rear wheels to rotate ? Could be the clutch plate is stuck to the flywheel if the car hasn't been used for a while. Let the engine heat up thoroughly - and allow the heat to soak through into the clutch - this sometimes frees it off. If not - release will involve trying to start the car in gear - with foot hard down on the clutch of course - either with the starter motor - or with towing. Just take care to not run into anything!
Postby FI Spyder » 15 Mar 2009 21:13
Did you change the clutch hose? New ones can be faulty and expand not allowing the hydraulic force be transfered to slave piston.
