OK what am I missing?
Postby FI Spyder » 08 Feb 2009 23:55
I decided to try and find out what my differential ratio is. I should have 3:45 being FI but I belived it to be 3:9. The number under the diff case is RKC0100. I couldn't find the number they usually refer to (CH1 etc. ) in the bottom LH side. The RH side was number 0391 poorly cast and difficult to read. When I turn the marked wheel one turn I get two revolutions of the marked drive shaft which is 2 to 1 give or take a bit. I thought I was possibley loosing motion at the other wheel so I jammed it with no difference. According to video on the web this is the way to do it (except they did it 10 wheel turns to make it easier accurately calculate the ratio. What am I doing wrong?
V8Wedgehead
Postby V8Wedgehead » 09 Feb 2009 00:04
The CL or CH etc. numbering to identify the gear ratio is actually in the middle of the bottom of the differential housing. The numbers are stamped and not cast. You will need to degrease the area to find the markings.
Michael
1980 TR8 FHC/Works Rally Project
Sondar
Postby Sondar » 09 Feb 2009 04:17
What I'm thinking (somebody please correct me if I'm being dumb!) is that the rotation of the prop-shaft would normally turn BOTH wheels, so if the drive is directed only to a single wheel, it will turn twice as far.
In other words, you have to take the result of turning a single wheel and multiply by two to get the correct answer.
Sondar
Postby john 215 » 09 Feb 2009 22:01
If all else fails, whip the cover off and count the number of teeth on the crown wheel and divide by the number of teeth on the pinion, the result is your ratio. Also dont do any harm changing the oil at the same time.
Users browsing this forum: Google [Bot] and 58 guests
