CAN ANYONE OFFER ADVICE ON THIS??
Postby tr7inc » 01 Feb 2009 13:21
Hi guys just a quick question to through at you, nothin major but was gonna change my fan belt today, and found that one of the 3 Alternator Bolts wont budge, ive tryed all the usually stuff but the thing wont move,the other 2 bolts i was able to slacken easily enough, but this one aint going anywhere and dont want to wring the nut on it, any suggestions??
Many thanks all
1979 Pre Production Prototype Inca Yellow DHC
Postby Beans » 01 Feb 2009 16:51
You only have to loosen the two nuts/bolts (arrowed in the picture) ...
This enables you to move the alternator enough to replace the fan belt.
The lower one can be rusted solid in the bracket/alternator.
Postby tr7inc » 01 Feb 2009 16:54
Beans sorry my appologies, i ment to say the 2 bolts of which i couldnt loosen, sorry for that mix up
Postby bmcecosse » 01 Feb 2009 18:50
Soak it in Plus-Gas. If still no good - apply heat!
Postby PeterTR7V8 » 01 Feb 2009 19:41
Bolts are cheap so if you have to then go ahead & cut it, grind it or split the nut.
Bashing a seized bolt with a hammer & cold chisel is great therapy.
Postby tr7inc » 01 Feb 2009 20:03
Peter, that was just the thought i was having myself, i'll try the heat method and if that dont work, try the hammer effect!
TR7Aaron
Postby TR7Aaron » 01 Feb 2009 21:06
I've had excellent luck with PB Blaster. Spray it, wait a couple minutes, take a few steroids, muscle up, and turn that bad boy!
Aaron
Postby tr7inc » 02 Feb 2009 09:17
Hi Aaron When the weather gets a better and less cold in me garage by hook or by crook a will shift the little devil.
Ianftr8
Postby Ianftr8 » 02 Feb 2009 10:00
Hi Steve,
Just a silly answer and I'm sure you have already checked, there isn't a nut on the back stopping you undoing the bolt is there?
If you do decide to go down the heat route obviously take great care with the aluminium parts.
Just a thought.
Ian
Ian Freeman
1962 Triumph Courier
Postby tr7inc » 02 Feb 2009 10:14
Hi Ian, many thanks yes i had thought that too, but did check and nothin behind it, i think if im being honest its just seized, i'll have a blast with some plusgas and see what happens, im sure if i persevere it will come in the end.
