NGK Spark Plugs
NGK Spark Plugs
Postby Maxwell » 16 Jan 2009 17:56
Hi Guys
Without wishing to be told the obvious, what's the difference between a NGK BP-5-ES and a NGK BP-6-ES?
What would readers recommend for a slightly warmed 2.0l Slant with a standard air-box [with K&N filter inside]??
Thanks.... and with luck <i>Robyn</i> should be at Gaydon on the 4th May!
Maxwell [:)]
Postby Beans » 16 Jan 2009 18:00
I use NGK BP5ES on a tuned 8v and it works pretty wel.
(car was set up on a rolling road)
Postby Maxwell » 17 Jan 2009 20:31
Thanks for that, Beans.
Fifty-three views and no other comments, so I guess there's not much difference!
Maxwell [;)]
Troy ODoherty
Postby Troy ODoherty » 17 Jan 2009 20:46
Hi Maxwell
The difference is the heat range of the plug. NGK plugs are colder as the number increses. The higher the level of tune the colder plug is required. Conversly in a worn engine that is burning oil it is common to use a hotter plug to burn of the carbon and reduce the chance of fowlling a plug.In race engines we sometimes use a warm plug ( low no) to start and warm an engine up and then change to a colder plug.If you can get BP6EY plugs use them. They are basically the same plug but the center electrode has a groove in it. This promotes a slightly better spark.
I would of thought a BP6EY would be about right, this is what is in my 8V and the V8 rally engine.
Cheers Troy
Postby Maxwell » 18 Jan 2009 14:40
Thanks for the information, Troy.
Maxwell [:)]
