Pop-up headlights - a dilema
macmattom
Postby macmattom » 12 Oct 2008 22:18
<font face="Comic Sans MS"></font id="Comic Sans MS"><font size="5"></font id="size5"><font color="blue"></font id="blue"><b></b>[:0]Hi - any advice greatly appreciated on my pop-up headlights. I've refurbished them and in trying out the motors they both worked great - individually [:)]. Then I wired them in together, in series, straight from the battery - only one would work at a time [:(]. Does anybody know if the lights are wired in "in-parallel" when fitted to the car, or is there a more sinister reason mine won't work together [}:)]. Thanks, Mac [?]
Postby Wayne S » 12 Oct 2008 22:29
They have individual circuits with a relay each. The headlight switch effectively switches two circuits on and off at the same time. So in effect when on the car they also only work one at a time but both on their respective circuit.
Postby jclay (RIP 2018) » 13 Oct 2008 04:15
Wiring diagram
Rayjones
Postby Rayjones » 13 Oct 2008 06:37
If you wired the two headlamp units together in series across a 12 volt supply they would divide the available voltage between them and effectively only be working on six volts each.
Ray
1980 UK BRG 2L DHC
