ITS RADIATOR CHANGE TIME
Postby tr7inc » 12 Oct 2008 07:01
Hi all just wondered from your own experience is it a long job to replace a Rad on the 7? mine aint that great and thought id replace it with the spare i had.
Many thanks
letstorque
Postby letstorque » 12 Oct 2008 08:12
Its quite straight forward. I think a a good screwdriver to loosen off the hose clips and a 13 mill or half inch socket/spanner is all you require. I'm sure someone will be along shortly to add a bit more.
<b><font color="blue">Eunos Roadster.
Fhat GS 300 Sport. Talbot Autosleeper with LPG.
If you ain't got 8, you ain't got enough.</font id="blue"></b>
Who is the randy Reindeer?
Postby tr7inc » 12 Oct 2008 08:43
Hi, yes, having looked in the Manual, it did seem striaght forward enough, just wanted an experienced view on it.
Many thanks
Postby Beans » 12 Oct 2008 20:13
If you remove the lower mouting croosmember you don't have to remove the fan assembly (if you still have it on that is)
Postby bmcecosse » 12 Oct 2008 20:21
Main thing will be to make sure you refill the system properly - with good anti-freeze and get all the air out of the system before going far in the car!
Postby tr7inc » 12 Oct 2008 21:22
Will do BM, many thanks all
