FHC side-vents
macmattom
FHC side-vents
Postby macmattom » 17 Sep 2008 23:17
<b><font color="red"><font size="2">Does anybody know of a suitable sealant to use to seal the gap at the top of the side-vent where it sits against the roof pillar? I was thinking of using a general purpose black silicone sealant, but is there any better option? I don't think the original seals are available any longer.</font id="size2"></font id="red"></b>
V8Wedgehead
Postby V8Wedgehead » 18 Sep 2008 01:12
Are you talking about the black grills/side vents behind the doors on the roof pillar? Or the window frame on the door?
Michael
1980 TR8 FHC/Works Rally Project
"If it is broken then fix it....if it is not then make it faster!"
macmattom
Postby macmattom » 18 Sep 2008 16:30
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by V8Wedgehead</i>
Michael
Sorry, I obviously didn't make it clear, but I was talking about the black grills/side vents behind the doors, on the roof pillars.
Mac
Mowog73
Postby Mowog73 » 18 Sep 2008 17:26
I'd suggest a urethane seam sealer.
Was seal sealer originally used on these side vents?
1973 MGBGT
1976 TR7
1980 Spitfire 1500
Postby Beans » 18 Sep 2008 21:05
Original there is a rubber foam strip at the top.
Postby Hasbeen » 18 Sep 2008 23:13
Wow. You learn something every day. Thanks for that Beans, I have
never seen anything there.
I suppose our climate destroyed rubber bits, quicker than yours.
Does not seem to let water into the car, without a seal. The flaps
under it must work well.
Postby Beans » 19 Sep 2008 17:55
It even has a BL parts number; ZKC2571 (supplied in 1 metre lengths)
macmattom
Postby macmattom » 20 Sep 2008 18:25
Thank you all for all your advice - it has given me some ideas. I guess I'll be adding quite a few more questions as I progress my rebuild.
Mac
[8D][8D][8D][8D]
