Gauge Upgrade
zekow1
Gauge Upgrade
Postby zekow1 » 05 Sep 2008 00:17
Hi Guys
I bought ,foolishly,
a SMITH Dual - Water Temp & Oil LB/O"
It did not come with Instructions nor pictures nor anything.Niente de piu.
Do any of you know how to install this thing,
Now that I have the car apart it would be easy to work it.
http://i280.photobucket.com/albums/kk18 ... fgauge.jpg
http://i280.photobucket.com/albums/kk18 ... /Back1.jpg
http://i280.photobucket.com/albums/kk18 ... /Back2.jpg
http://i280.photobucket.com/albums/kk18 ... tubing.jpg
cliff
Postby cliff » 05 Sep 2008 06:25
zekow, regarding installation your Smiths Dual gage, the armoured cable is the temp cable that gets fed thru the firewall and installed where the electrical temp sender is located. The oil pressure gage, the plactic line w/attaching compression fittings will also be fed thru the firewall and be fitted onto the oil transfer housing. Remove the electric switch and replace the switch with a male-female-female pipe Tee, reinstall the eletric switch on one end of the Tee, install compression fitting to the other end of the Tee, you may require an adapter to connect the compression fitting to the Tee. Top off coolant start and check for leaks. The 3 wires coming off the oil pressure switch, white/purple wire goes to the anti-run-on valve. Black is ground/earth, white/brown goes to the idiot lite. Hope this helps!!
Cliff
zekow1
Postby zekow1 » 05 Sep 2008 18:05
Cliff
Thank You[:)] , The information is very precise
Question?[?]: on the Armored unit to be placed on the location where the Electric temp sender is located.
could there be a way to keep them both connected ,Like a Y Connector adapter????.
I WANT TO HAVE MY CAKE AND EATED TO.
What a weard expretion ,But I think it describes The idea .
RJS
Postby RJS » 05 Sep 2008 18:14
Zeke,
Have you seen this link before?
http://www.waringstowntr7s.co.uk/oilgauge.htm
Rob
cliff
Postby cliff » 05 Sep 2008 20:02
ZEKE, yes, you could use a Y connector, but it will work best if the sensor is in the water jacket, otherwise you are sensing temps outside the block/waterjacket and not in the waterflow path.. Hope this helps!!
Cliff
zekow1
Postby zekow1 » 05 Sep 2008 21:25
Cliff it makes since ,
How about placing it somewhere else??
Rob
Hey !!buddy thank you for the link it makes it easier for me.
Do you want to trade places this week coming up
I'll kindly move to the desert and you can start preparing for the Hurracaine?????
Have Fun /Be safe
RJS
Postby RJS » 06 Sep 2008 05:14
Zeke,
Even though it will be close to 110' this weekend I think I will stay put.
You be safe and keep us posted.
Rob
Postby bmcecosse » 06 Sep 2008 17:16
When you take the old temperature sensor out - make sure there is enough space to install the bulb of the new gauge without damaging it. Also - take very great care of that sensor pipe (it's ether filled) - it must not be twisted or kinked - and must be well protected where it goes through the engine bulkhead.
