THE CLOCK!
MickeyR
THE CLOCK!
Postby MickeyR » 25 Aug 2008 22:26
Yeah, I know - this has been beaten to death.
But I may have stumbled on to a fix that I haven't seen on either this forum or any other venue.
After taking several dash pods apart in my feeble attempt at mounting an oil pressure gauge, I finally got hold of a working clock, and decided to put it in and mount an oil pressure gauge separately. After CAREFULLY removing said clock to install it in my "new" cluster, then installing it, no go. So, I pulled the clock out, sprayed it liberally with electronic cleaner, then just a tiny amount of WD40, and hooked it up to a battery. Started ticking, then slowly stopped. Interestingly, though, as long as it was upside down, it would run fine! As I rotated it more upright, the pendulum would slowly stop. Pulled the two cover brackets off and noticed that the pendulum rides on what appear to be set screws. AHA!
So, I fired it up again (upside down) and very gently turned the bottom set screw one way. Pendulum stopped immediately. Turned it back the other way to where it was, then a fraction more. EUREKA! I can now mark the passage of time without standing on my head! Albeit at a deficit of a couple of minutes a day, but, hey, it's Smith's, isn't it? [:D]
At any rate, after a week, it's still ticking away happily, and now it's time to move on to finding a good place to mount the oil pressure gauge.
Hope someone can use this EXTREMELY valuable information! ~Snicker~
Best,
Mickey
Postby bmcecosse » 26 Aug 2008 15:45
What was the problem with fitting an oil gauge in place of the clock ? I ask - because although my clock keeps perfect time (even when laid up over winter!) - I would rather have an oil gauge and rely on my watch for time ! I don't want to wreck my perfectly good panel to fit an oil gauge if it's not straightforward ?
Postby Rich in Vancouver » 26 Aug 2008 18:25
I fitted a Smiths oil guage without much bother at all. I just dremelled away the absolute minimum of plastic fron the panel and used the original Smiths bracket to secure it. Works great!
Rich
MickeyR
Postby MickeyR » 26 Aug 2008 19:46
My "feeble attempt" remark was somewhat tongue-in-cheek. I played around with mounting one, but decided I liked having the original layout of the dash pod. Will be adding an oil pressure gauge in a separate pod at some point, but for now...
Rayjones
Postby Rayjones » 27 Aug 2008 01:43
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MickeyR</i>
Best,
Mickey
Hi Micky,
My clock has happily ticked away the last eight years away since I did something similar, seemed to remember that I made one good clock out of two duff ones. With any luck yours will be OK too.
Ray
1980 UK BRG 2L DHC
MickeyR
Postby MickeyR » 27 Aug 2008 11:34
Thanks, Ray! Good to hear it!
Best,
Mickey
Bill
Postby Bill » 27 Aug 2008 11:40
<b> Is there a way to adjust the clocks? Mine picks up a couple minutes a week, so I always have to set it <i>back!</i> </b>
Bill
1980 Persian Aqua DHCImage
Rayjones
Postby Rayjones » 27 Aug 2008 13:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Bill</i>
Bill
I don't think there is any set agjustment, the mechanism is not quartz crystal controlled like a modern clock, it's transistor driven. Accuracy of a couple of minutes a week is as good as it gets, mine loses a little, more so in the winter during cold weather.
Ray
1980 UK BRG 2L DHC
MickeyR
Postby MickeyR » 27 Aug 2008 14:00
[quote]<i>Originally posted by Rayjones</i>
[quote]<i>Originally posted by Bill</i>
Bill
Ray
1980 UK BRG 2L DHC
If you look at the top of the clock, there's a hole through which you can see,right above the spring, a notched silver piece. I think that's the adjustment - take a small screwdriver and you can rotate it one way or other.
Bill
Postby Bill » 28 Aug 2008 13:02
<b>Will do, thanks!</b>
Bill
Ferris
Postby Ferris » 29 Aug 2008 12:50
Clock? What clock?
My oil pressure holds steady at 6:00 [:D]
It's true! Bob IS my uncle!
Kevin Anderson
(2)1980 TR7 DHC
1990 Jaguar XJ40
Users browsing this forum: No registered users and 77 guests
