Ball Joint How to get it back in?? >> HELP
nguada
Postby nguada » 29 Jul 2008 14:12
A new ball joint is killing me, it wont come in.
Any tips, tricks that I should follow?
I got a Ball Joint Press but I am not strong enoughs, I will try with an Impact Wrench next.
I heard about freezing the ball joint or heating the arm or just giving up and taking the arm and the ball joint to a Garage with Hydraulic Press.
Any advise is welcome.
Thanks
Natalio Guada
Pembroke Pines, FL
Postby bmcecosse » 29 Jul 2008 14:44
How did you get the old one out ?
nguada
Postby nguada » 29 Jul 2008 14:58
I use a gear extractor, when I use it the other way, I damage the new ball joint since I applied the presure on the softer center.
Postby FI Spyder » 29 Jul 2008 20:20
This one job I leave for the garage and it's press not that I wouldn't like a press and accessories.
Postby bmcecosse » 29 Jul 2008 21:45
Can you not fit something like a large socket over the 'soft centre' - pressing on the outer rim - and then pull it in that way ?
laskaboots
Postby laskaboots » 29 Jul 2008 21:58
doesn't the threaded rod part go through the tapered hole far enough
to get the nut started, then pull it in tight by wrenching on the nut?
Sondar
Postby Sondar » 30 Jul 2008 00:34
That's the way I've done it in the past - although I seem to recall having to hit the top of the joint with a hammer to get it far enough through to get the nut on. Not exactly subtle, but it worked.
Sondar
jazzie
Postby jazzie » 30 Jul 2008 13:26
Moog Chassis and TRW Chassis have a ball joint tool, It is a giant C Clamp which allows the stud to pass thru the top of it...There are adapters that fit just about every ball joint..You take your impact to the screew nut and press the joint into the control arm..
It is a pretty cheap item..
Postby bmcecosse » 30 Jul 2008 18:37
Any chance you could post a picture of that ball joint tool, jazzie ??
nguada
Postby nguada » 30 Jul 2008 19:37
Thanks for all the sugestions
I took the sugestion from "FI Spider".
I took out the arm out and took it to a garage along with the ball joint.
The press it in with a "Hydraulic Press".
I believe the specs of the replacement part here is the states are a little over the top and prevented the other methods to work.
This one is over, more to come.
Thanks again
jazzie
Postby jazzie » 31 Jul 2008 12:21
BM,
I will see what I can do about getting a picture of the clamm / tool.
Postby bmcecosse » 31 Jul 2008 18:18
Ok thanks 'jazzie' !
Postby FI Spyder » 31 Jul 2008 18:59
Hers a link to Harbour Freght's ball joint press kit:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
For Thirty five bucks it's a good deal compared to $180.00 I had priced out last year from local supplier. But then there's shpping.
nguada
Postby nguada » 31 Jul 2008 19:27
I was using the tool from Harbour Freght the $35 one.
It was failing, as I was pressing the ball joint in, the C started to bend instead of pressing the ball joint in.
maybe the adaptors and the sleves could be used with a real press
Made in China [:(]
Postby FI Spyder » 31 Jul 2008 20:08
I guess that's why it's $35 and not $180.[:)]
Users browsing this forum: No registered users and 80 guests
