MGF ally wheels Definative answer
Gareth
Postby Gareth » 24 Jul 2008 18:12
Hi All,
Great site been a member for the last 3 years but my first post, reason being bought my first TR7 12 years ago I was lead my heart and not brain bought a rot box (looked good though) then bought a semi restored auto with god body for peanuts so I could re shell.
Chopped up the old one but never got round to actually re-shelling it.
Any way to cut a long story short I last month bought a TR7 DHC off ebay for what I thought a reasonable price. She has only done 55k and is structually solid (well happy).
Well the question. There are many thread on fitting MGF alloy wheels but nothing definative.
1. Are they a straight fit or do you need spacers??
2. Originally they come with the profile 185 at the front and 205 at the rear. what is the best option 185 or 205 all round or as they come with 185/205.
I am just looking at what is the answer as many of you have fitted them and the standard wheel trims to put it politely look crap!!!!
Thanks for your input
Gareth
Postby bmcecosse » 24 Jul 2008 21:43
I haven't done the job - but I believe they fit straight on with 'maybe' some slight fettling of the centre hole so they can fit snuggly on the hub. Someone will be along in a minute who has done it!
Postby stevie_a » 24 Jul 2008 22:03
<font color="purple"><b>I have MGTF V spokes
Fitted right on no modification at all
Although I have not got any spacers I am thinking of putting on 3mm spacers
Just for cosmetics to fill the arches a bit more </b> </font id="purple">
Image Image Image
Postby TR Tony » 24 Jul 2008 22:05
Gareth - the MGF alloys will fit straight on. They are one of the few modern alloys that have the correct PCD of 95.25mm to fit the TR7 hub. I have not heard of anyone having to use spacers.
They come in 15" with a 6J width, & 16" with a 7J width. Most people use the 15" "minilite" style as they are relatively easy to find at a good price, but AFAIK all the styles will fit.
Points to note are that the offset is different to the standard TR7 wheel, & the centre bore hole is very slightly smaller than the hole on the TR7 wheel, so some people have this machined out.
I've got 195 tyres all round on mine (15") but I think 205 will fit if you want them.
1980 3.5L V8 DHC Jaguar Regency Red</font id="size1">
Sondar
Postby Sondar » 24 Jul 2008 23:18
Just be aware that if you fit the 16 inchers, the tyres MAY rub on the arches at the rear because of the 7 inch width. The other point about the 16 inch wheels on the MGF is that they carried 215 rubber - front and rear.
Sondar
Postby PeterTR7V8 » 25 Jul 2008 00:34
15" x 7" rims will allow you to fit up to 215/50s without rubbing but I've gone with a 225 on the back which has a slight rub at the 10 o'clock point of the arch on the bigger pot holes round town. The same tyre on the front would pull the lip at the top of the arch which was a complete nuisance.
diver
Postby diver » 25 Jul 2008 13:06
OFFSET: What is the offset for the TR and MG?
dIVER
Postby bmcecosse » 25 Jul 2008 14:28
Stevie_a - what wheel bolts did you use with these wheels? The original TR7 bolts - or bolts from the MGF - or, something completely different!
Postby TR Tony » 25 Jul 2008 15:29
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by diver</i>
dIVER<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The TR7 offset is 25mm, the MGF is 30 or 35mm depending on the actual style of wheel used.
Postby stevie_a » 25 Jul 2008 16:13
<font color="purple"><b>MGF nuts </b> </font id="purple">
Image Image Image
Postby bmcecosse » 25 Jul 2008 21:23
Excellent - now we know !! Maybe this thread should be a 'sticky' ?
manwithtool
Postby manwithtool » 30 Jul 2008 20:08
So what size tyres....Just bought a set of the minilite wheels...but the 205 50 15 looks to be a bit small ?? I plan on going with a 205 55 15 size tyre, unless anyone can tell me why I shouldn't...
Currently have 175 60 (i think) on 14 " minilite wheels..
Martin
If it isn't broken, I can still fix it
mikehardwick
Postby mikehardwick » 31 Jul 2008 09:03
Martin - your speedo will underread by 3.5% at 60 mph - i.e. it will show 58mph at a true 60. Not disasterous, but worth bearing in mind when flirting with the revenue cameras!
Mike
1981 TR7V8 DHC
TSSC N. Yorks A.O.
Sondar
Postby Sondar » 01 Aug 2008 00:18
Just one comment re Peter's statement that 215/50's on a 15x7 will fit without rubbing.
This is not necessarily true!
I've got 205/50's on 15x7's and had to get the rear wheel arch lips rolled up to stop the off-side rear rubbing.
The car is straight with fully refurbished suspension, so that wasn't the cause of the rubbing on one side. Revington TR did the work on the arches and did some comparisons against other 7's in their yard which had a similar slight asymetry to the bodywork at the back end.
Basically, it seems that some cars will take wider tyres than others without contact to the arches. So check it out first!
Sondar
Postby bmcecosse » 01 Aug 2008 14:31
If it only rubs one side - not the car is not true!! The axle (or rear end) must be off centre.
For information - my 195/65 x 14 tyres are close but don't rub - and the speedo reads high by 9% all through the range. ie 109 mph is really only 100 mph!
Users browsing this forum: No registered users and 90 guests
