Removing the grills on a FHC
Postby UKPhilTR7 » 18 Jul 2008 14:01
<font face="Tahoma"><b>I have a FHC and I need to remove the black plastic grills from the sides behind the doors to do a little rust treating.
I am right in thinking all I need to do is get a little screwdriver under the black plastic clips and ease them out gently?</b></font id="Tahoma">
Postby Hasbeen » 18 Jul 2008 14:57
No. You have to remove the trim inside the car. You then discover
that those funny little things are bolts, & nuts. They undo easily,
but are old plastic, & inclined to be brittle, so go easy on them.
Postby Beans » 18 Jul 2008 17:58
And usualy the little nuts are very rusty, at least in our rather moist Dutch climate. So they are very tight as a result of which the plastic bolts snap very easily.
A good soaking with penetrating oil may save a few of the plastic bolts. Take your time ...
Postby UKPhilTR7 » 21 Jul 2008 10:39
<b>Cheers for this guys. It is a good job that I asked as if not I would of broken either the grill or the screw.
So to get to it from the inside do I just pop of the L shape cover?</b>
tr7sprint1
Postby tr7sprint1 » 21 Jul 2008 11:23
Yes, remove the L-shaped cover.
Users browsing this forum: No registered users and 82 guests
