Engine oil again
Johnluss
Engine oil again
Postby Johnluss » 18 Jul 2008 01:40
I would like to pass this info to all british car lovers.
The local distributor for parts in my area came with this. He is saying hat oil compagny have removed fron traditionnal oil the ZDDP (Zinc Dialkyl Dith....) because car compagnies asked them to do so because this additive was ruining the catalytic converter on new cars. And of course he has the oil with the additive or additive to add to regular oil.
I would like to have your comments on this.
Johnluss
Postby Johnluss » 18 Jul 2008 02:08
Forgot to mention that this ZDDP is essential to old engine specially rebuild crankshaft
Postby Hasbeen » 18 Jul 2008 03:10
Back in the 60s, when I was racing, this zinc was still a normal
additive in most oil.
However, with every gallon of racing oil Schell gave us, they
included a bottle of about half a pint of liquid zinc. For some
reason, not explained to us peasants, it had to be added after the
new oil was up to operating temperature.
So even when it was in normal oils, more, or another type added, was
better, for high stress usage.
ACW30445
Postby ACW30445 » 18 Jul 2008 16:51
ZDDP has NOT been removed from oil. I has been reduced to 'nominal maximum' of 800 ppm in the SM-GF4 spec oils listed as 'Energy conserving'.
The problems I am aware of mainly deals with flat tappet cam pushrod engines. Many people are reporting early cam/ lifter failures...but then there's the issue of the influx of Chinese made 'offshore' lifters and other metallurgical issues, changes to valve train geometry, not to mention high lift cams and valve spring pressures many people use now in 'musclecars'.
An OHC design as a rule produces less stress on the lifter face than a flat tappet pushrod design also. Without making this too long, while the issue is much debated, oil manufacturers have always succeeded so far in making oils 'backwards compatible'. The story some promote that the 'new oil' takes no consideration for older engines is flat wrong.
For most stock engines after break in under normal conditions I think it's much like the 'you must install hardened exhaust seats' myth.....for all the people who quote this and say they know it's absolutely true you can find equal numbers who have been running on unleaded for decades in a wide variety of engines with no problems.
Actually in the old days (contrary to popular conception now) high lift cams often failed early. The OEM factory cams often were phosphated and the factory lifters often had a special hardened foot on them (speaking of flat tappet pushrod cams here). There are a lot of variables here and the 'new oil' is the easiest target to find.
Keep in mind when people speak of 'British car problems'...how many are thinking of problems proven in the Triumph 2 liter OHC engine?
Probably about ZERO!
http://www.allpar.com/old/oils.php
"I talked with the OEMs in Detroit. The API SM IILSAC GF-4 engine oils should be suitable for older engines with flat fappets. The specification testing for oils with this performance category includes two engine wear tests (Seq. IIIG and Seq. IV) which use engines with flat tappets. Both the Seq. IIiG (GM engine) and Seq. IV (Nissan engine) are flat tappet engine tests measuring wear. For an oil to meet the specification these wear and scuffing tests must be passed. You will remember that API SM/GF-4 engine oils have a phosphorus limit of 0.06% min. and 0.08% max. It is also important to use the recommended viscosity grade (e.g. SAE 10W-30, SAE 10W-40).
An alternate suggestion is for those who are not convinced they may wish to use oils meeting the new API CJ-4. Although designed for diesel engines it has lower ash levels. Phosphorus levels are as much as 0.12%. API CJ-4 engine oils should be showing up in stores shortly. It may be possible to find these oils in SAE 10W-30 as well as the [other grades]."
ACW30445
Postby ACW30445 » 18 Jul 2008 17:46
Further reading:
http://www.wbclassics.com/eng102-t.htm
Delo 400 15w/40 is easy to find at any Wal-Mart BTW...at least in Texas.
I read another piece by another TR6 vendor which I don't have handy but said in effect 'when the Chinese lifters went away...the problem went away'.
Johnluss
Postby Johnluss » 19 Jul 2008 14:00
Thanks for your answer and all the info included. I have forwarded your answer to the distributor.
Users browsing this forum: No registered users and 77 guests
