Alternator problems
jazzie
Alternator problems
Postby jazzie » 15 Jul 2008 22:33
Alternator dies, run on battery to my shop half way there the clock starts to work...It hasn't worked in 5 years now it decides to work..Replace alternator and the clock stops...Just for kicks we decide to disconnect alternator and run on battery...You guessed it the clock works....Any thoughts....
Postby Beans » 16 Jul 2008 18:59
Lucas electrics [:p]
Had the Sprint in for its MOT yesterday.
Checked the car over the day before and the beam flash didn't work. As it's not an MOT failure I checked only the obvious things but couldn't find anything wrong.
At the MOT station they just worked fine ...
Postby bmcecosse » 16 Jul 2008 20:12
Must be something to do with high volts when alt is working! I suppose you could make up a voltage dropper circuit - and feed the clock with say 10 volts.
Postby jclay (RIP 2018) » 17 Jul 2008 04:01
Heres the deal. The clock feed and the alternator all connect at the same place. It uis the biggest problem with corrosion on the car as it is right next to the battery.
The black connector on the red battery cable is the source of many problems. First disconnect the positive battery lead. Undo the connectors at the black connector and check for corrosion. Clean all of the connections. If there is a lot of corrosion in the connector, mix some water and backing soda together and use a small brush to apply the solution to the connector. DO NOT LET IT GET ANYWHERE NEAR THE BATTERY!!
You may have to do this several times to clean it well, then rince with clean water and dry. Once you have all the wires cleaned up, reconnect the wires and then the battery cable.
Users browsing this forum: No registered users and 82 guests
