Pulls to the right
HDRider
Pulls to the right
Postby HDRider » 15 Jul 2008 22:21
So my 1979 DHC pulls to the right at speed when the brake is applied. It feels more like it is in the rear of the car. The rear brakes seem fine and I am starting to think that it might be soft rear bushings. I am going to check on different inner diameter of the drums tonight. Any thoughts/experiance with this problem?
Edward Hamer
Petaluma CA
jazzie
Postby jazzie » 15 Jul 2008 22:31
HD Rider,
Check your front calipers they tend to stick causing excessive force being applied therefore causing the car to pull to the right uder braking...
HDRider
Postby HDRider » 15 Jul 2008 23:11
I checked the calipers and they are free. The pads are not binding in the calipers either.
Edward Hamer
Petaluma CA
Postby PeterTR7V8 » 16 Jul 2008 00:24
The rear wheels don't steer (hopefully) so it is usually a front brake problem.
How strong is the pull? If the car is pulling dramatically it will definately be because one of the front brakes aren't working.
Have you bled the front & made sure the fluid is pumping to each caliper?
Troy ODoherty
Postby Troy ODoherty » 16 Jul 2008 00:57
Check the front suspension. possible soft shock or spring or worn sway bar bushes.
Cheers Troy
cliff
Postby cliff » 16 Jul 2008 04:55
I once had a tread seperation that gave me a warning by pulling to the side that seperated a few days later. The second part was a vibration that was followed by the actual seperation. I was lucky that nothing was damaged by the tread flailing around. I recommend that you have a good tire shop check out your tires for an inpending failure. Sometime radial tires will pull, if you have radials on all four corners you might also try a tire rotation to see if the pull follows a particular tire. Cliff
HDRider
Postby HDRider » 16 Jul 2008 15:46
I replaced the tires and the problem is the same.
I checked the left rear bushing last night and there is at least 1/4" of free play. I have orded some new poly ones and will see if that makes a difference.
The complete brake system has been bled and both front calipers checked by the way. The rear brakes were replaced just before I purchased the car.
Edward Hamer
Petaluma Ca
Postby Beans » 16 Jul 2008 18:58
Also worth to check the suspension alignment.
What (size) wheels and tyres are you using, wider tyres may emphasise small faults.
Postby jclay (RIP 2018) » 16 Jul 2008 19:01
Have you checked the FLOW through the brake lines? If there is residue or corrosion build up in the brake lines, one side will not flow as well as the other, causing a pressure differential between the two front brakes.
HDRider
Postby HDRider » 16 Jul 2008 21:39
Brand new stock TR7 wheels with 185/70 x 13" tires.
Flow to the calipers seemed fine when I tested the piston movement and when I bleed them.
Edward Hamer
Petaluma CA
HDRider
Postby HDRider » 24 Jul 2008 22:32
I installed new poly bushings in the rear swing arms last night and it seems to have cures the pull. The forward one on the left side was badly worn and allowing the axel to move for and aft 3/8" to 1/2".
I was fortunate in that it was a dead easy job. The bolts came right off and my 20 ton press made fast work of removing the old bushings.
Edward Hamer
Petaluma CA
Users browsing this forum: No registered users and 80 guests
