Stiff Heavy Steering
indiadog1
Postby indiadog1 » 10 Jul 2008 18:14
Now I have had chance to drive the car I have noticed that the steering is heavy,a little clunky and there is play in the steering wheel up and down. Any Ideas?.
MickeyR
Postby MickeyR » 10 Jul 2008 18:18
It's not uncommon for the bushing through which the shaft passes in the bulkhead to crumble. Could be your problem Replacement plastic bushings are available from Rimmer Brothers...
Mickey
Postby bmcecosse » 10 Jul 2008 20:08
The stiff steering could be down to need for grease in the rack and the track rod ends - but also check the two little universal joints twixt wheel and rack - they could be seized. try soaking them in release oil. Steering column movement will require new bushes.
