pacet fans
davesopener
pacet fans
Postby davesopener » 09 Jul 2008 17:02
hi,
sorry for appearing dumb here!
my cars fan stopped working just recently
im not sure where the fuse for this will be located
doesnt look like a loose wire
thermostat may need changing
any advice
thanks[8D]
Postby PeterTR7V8 » 09 Jul 2008 22:07
When this happened to me it turned out the power wire to the thermo switch was dead. I ran a new wire from the battery with a fuse rather than tear the dash apart looking for the origin of the original wire. As a result the fan works after the car has been turned off but I don't see this as being a negative.
So, check the thermo. You should be able to hear it click when you turn the adjustment knob. If it clicks it works. Next, adjust the thermo so it is on at garage temp, get a volt meter & check there is 12v getting to the thermo & to the fan. If the thermo has no power do what I did. If the fan has no power you probably have a busted relay.
Or, take it to an auto electrician & they will probably have it fixed within an hour & you can have your weekend back.
davesopener
Postby davesopener » 10 Jul 2008 15:26
ty peter
davesopener
Postby davesopener » 10 Jul 2008 17:30
ty
yeah somehow setting had changed on switch working fine
ty
Postby PeterTR7V8 » 10 Jul 2008 21:39
Good to hear.
In my case the whole episode resulted in a new set of cylinder heads.
davesopener
Postby davesopener » 11 Jul 2008 11:04
nightmare poor u peter
hopefully this aint happening to mine
ty
dave[8D]
