Sagging side lite surounds
Postby paul w » 05 Apr 2008 21:08
You know those plastic black surrounds around the side light that fit
into the front bumper.Well i am fed up of seeing 'em droop!Nearly all
the wedges i see has this problem.I tried submerging them in ho****er
reshaping and plunging in cold water to set,and then super gluing to
the bumper.This works for a time,but after a while they sag again.
Does anyone have a cure for this affliction?
Postby Odd » 05 Apr 2008 21:31
The US bumper skin? No need for them there...
Postby paul w » 05 Apr 2008 21:49
The USA spec bumper uses these too.Part no:YKC874,I think your on
about the bumper corners,Odd,not the sidelight surrounds.
Postby john 215 » 06 Apr 2008 09:26
Hi Paul,
I running a US spec front bumper and although Rimmers ect list them for this bumper i am not running them myself. Will brave the blizzard outside [;)] (well snow shower but you know what happens when we have 1/8" of snow!!!) and take a picture. The repo surrounds you can get now seem to be made out of a softer material not sure if that would fit any better?
Cheers John.
Postby Odd » 06 Apr 2008 12:01
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> The USA spec bumper uses these too. Part no:YKC874,
I think your on about the bumper corners, Odd, not the sidelight surrounds. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> No Paul, you're wrong here!
The US type skin have these surrounds as an integral part of the skin. The parts listings are wrong in this.
So, I maintain: Fit the skin and your problem is over.
Best regards,
/Odd
Postby paul w » 06 Apr 2008 12:44
Sorry Odd,did'nt realize this,but it still wont help on the Viper
front,which uses the surrounds.
So,fella's,a solution for this perrleeeezzzze!
Postby jclay (RIP 2018) » 06 Apr 2008 13:02
How about reinforcing them with a strip of metal on the top of the pod?
You could install the strips on the outside, top of the pod before you install the unit so that the stirp is hidden behind the bumper cover. And since hardly anyone ever gets on the ground to look at the pods, the attaching screws, nuts, pop-rivets, etc. wouldn't be seen.
Just a suggestion!
