Fascia scratch removal
Red
Postby Red » 04 Apr 2008 21:20
As part of my resto, I've taken the dashboard out and I'm currently going about cleaning and repairing the instrument cluster, among other bits. So far so good, but I'm having a struggle removing all the scratches from the clear plastic cover.
So far I've tried:
T-Cut: Bit of a disaster that, it's too strong and actually made it worse in areas.
Toothpaste(!): Didn't really make much difference. It did make it smell minty fresh though!
Brasso: Seems to work, the scratches are coming off, but it's taken ages so far just to do a small area.
Now I've run out of stuff around the house, can anyone recommend anything that'll do the job? Or should I stick with the brasso and resign myself to using a lot of elbow grease?
Garry
1976 2.0 (soon to be 3.5!)FHC
http://reds-tr7.blogspot.com/
Henk
Postby Henk » 04 Apr 2008 22:09
I should say Brasso, used it for watchlenses also.
But maybe this stuff; Renovo Plastic Window Polish works better.
http://www.frost.co.uk/item_Detail.asp?productID=8840&frostProductName=Renovo%20Plastic%20Window%20Polish%20(50ml)&catID=15&frostCat=Car%20Care&frostSubCat=Renovo&subCatID=25
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby FI Spyder » 05 Apr 2008 01:39
I always use Novus #2 plastic polish for hard plastics.
http://www.novuspolish.com/
Postby Rich in Vancouver » 05 Apr 2008 02:01
I agree, Novus is a good product.
You should be able to find Novus or similar products at marine or aircraft supply outlets.
Rich
Rblackadar
Postby Rblackadar » 05 Apr 2008 06:50
I used a cd scratch remover kit for less than 10 bucks....looks great!
EntonoX
Postby EntonoX » 05 Apr 2008 09:46
You can also buy a new clear gauge plate? Don`t know what these cost today...
EDIT: only AEU1810 is new available in holland, costs 21 euro`s but that is no use if you have an early car with cable reset, because you then have a hole in the glass.
TR7, ACG 2700L
Red
Postby Red » 05 Apr 2008 19:54
Thanks guys, I'll take a look at those.
As far as I can make out, the new covers are NLA over here, so polishing it is.
Garry
Postby paul w » 05 Apr 2008 21:59
Robsport warned me that even the new old stock ones have scratches,so
i tried polishing them out.I agree with Henk that Brasso worked best.
Ianftr8
Postby Ianftr8 » 06 Apr 2008 09:51
Hi Chaps,
I used a very cheap Motorcycle visor cleaner spray from Lidl or Aldi and that seems to have worked really well.
worth a go.
Ian
Ian Freeman
1979 TR8 DHC California car that never crossed the pond
1962 Triumph Courier
EntonoX
Postby EntonoX » 15 Apr 2008 11:40
Quick update on this:
As i am restoring a TR7 myself, i began yesterday with the instrument/speed panel. As i was looking at the facia i was shocked to see that i almost couldn`t look through it!
What i did to restore the facia was this:
- Clean the facia with water and make sure all dirt was off.
- Take sanding paper P1000 and wet sand the panel in circular motion.
- Take sanding paper P1200 and wet sand the panel in circular motion.
- Take a special polishing pad which is about P3000, this pad is from 3M and most car paintshops have these. Wet sand it with P3000 pad in circular motion.
- You now have a real smooth milk like surface.
- Take some toiletpaper and some Brasso copper polish and polish the facia in circular motion until the brasso is almost dry.
- Then quickly whipe off the brasso residue and polish the facia with some ordinary car wax/polish.
Voila, your brand new facia! please not that the P3000 pad is absolutely necessary, without it you can`t get the ultra clear finish.
TR7, ACG 2700L
