Collapsible Spacer (Crush tube) on pinion shaft
Thom
Postby Thom » 12 Jan 2008 03:57
I'm changing the gear ratio in my 1980 Tr7 DHC from 3.9 to 3.08, and I'm having trouble sourcing the crush tube that goes on the pinion shaft between the inner and outer bearings. Does anyone know where these can be purchased? If not, has anyone tried flattening the raised portion of an old one using a bar, and reused it?
Postby Beans » 12 Jan 2008 10:51
Never re-use them, as they won't give the correct tension on the bearing.
mikehardwick
Postby mikehardwick » 12 Jan 2008 21:08
They're like hens teeth! I've heard of one source who claims to have a couple but he is no longer trading. Triumph specialists I have spoken to resort to 'reprofiling', but admit to having to make several attempts to get an acceptable result - and yes, the only way to check the result is to refit the rebuilt axle and drive the car!
Beans, do you know of a source?
Mike
mikehardwick
Postby mikehardwick » 12 Jan 2008 21:09
Sorry guys, finger trouble - [:o)]
Mike
Postby Beans » 13 Jan 2008 16:00
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mikehardwick</i>
...Beans, do you know of a source?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Sadly not. My experience is that traders often wont sell you the parts because they can "earn" more money if they rebuilt the axle for you [:(]
scotty
Postby scotty » 18 Jan 2008 10:30
Wonder what the guys at S&S or Robsport etc do with diff rebuilds? Do they have old stock, or have them remanufactured, or reuse the originals somehow? Anyone able to comment?
A pessimist is never disappointed!
Postby john 215 » 18 Jan 2008 17:03
Would'nt be hard to remanufacture i would'nt think [?] by far the biggest problem would be finding out what type of steel used as this has a effect on its crushabilty. 'Back in the day' we had loads of these kicking around at work, like lots of things wish i had kept some new ones 'in stock' for future use.
