enamelled Triumph badge
ggreen
Postby ggreen » 29 Dec 2007 20:29
Any idea as to what glue I should use to stick the "Triumph " enamelled badge back on the nose panel with ?
Postby Chris Turner » 29 Dec 2007 22:20
We use double sided tape, similar to the stuff used to stick interior mirrors to the windscreen.
www.triumphtr.co.uk
SJW 539S TR7 sprint
1980 TR7 Premium.
Henk
Postby Henk » 29 Dec 2007 22:21
I think you can use this double sided tape from frost.
http://www.frost.co.uk/item_Detail.asp?productID=9298&frostProductName=Double%20Sided%20Tape%2012mm%20wide,%2010m%20long&catID=&frostCat=&frostSubCat=&subCatID=
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby silverseven » 30 Dec 2007 02:32
I've allways been using 3M double sides adhesive "red" tape for re-attaching mouldings , nameplates and trims in the bodyshop.
By far we've allways found 3m's products superior to others.....
ggreen
Postby ggreen » 31 Dec 2007 16:27
Thanks Guys. I know of Frost. I purchased some POR15 from them in the past. I will give them a ring.
fiveliters
Postby fiveliters » 02 Jan 2008 18:44
ggreen-where did you even find one of those? I know that VB carries them,but they also want $70.00 for one![:0] I just bought the center cap for the steering wheel which closeley resembles it on eBay for $11 brand new and will have the local print shop do an enlargement and clear vinyl coat it for me for free (helps when the owner is your neighbor!). I was never crazy about the whole wreath/script thing,and the decals on the trunk are sort of worn,so I am having both removed,and the badge put on in the front,and the actual metal letters from an earlier Triumph put across the rear boot,Lotus-style.
Postby paul w » 02 Jan 2008 23:20
fiveliters,that badge is still listed by Rimmers - XKC3902
for £30. Dunno'what the exchange rate does to that,then
there's the shipping! Some times appear at auto jumbles
for less than 30 notes,i'll keep a look out for ya' if you
want one.
mb4tim
Postby mb4tim » 03 Jan 2008 02:36
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fiveliters</i>
...so I am having both removed,and the badge put on in the front,and the actual metal letters from an earlier Triumph put across the rear boot,Lotus-style.
That's gonna look sweet!
-Tim
Postby john » 03 Jan 2008 07:27
i've often seen the enamelled badges going for under a tenner at the autojumbles
one guy had three or four at Beaulieu last year on his stall
