What have I done?
What have I done?
Postby Hasbeen » 04 Nov 2007 13:14
After what seems like years the decision has to been made to
recondition the BMW sourced ZF auto in the 8, rather than fit a
Toyota Supra 5 speed in its place. I have it booked it in for tuesday
morning.
I therefore fitted a good, fully charged battery & went through the
procedure, until I got to the bit where the starter motor should get
involved. Nothing.
The last time this happened it was a flat battery in the fob, not
turning the immobiliser off. No the little light was off. As the
thing has only been run every couple of weeks for some time, I
assumed dirty connection.
Being a complete ignoramus when it comes to things electrical, &
many other things, my wife would say, I cleaned every connection I
could think of, but still nothing. I was now at a complete loss,
until I remembered an alternator, which had to be convinced I was
serious about requiring it to work, by getting a belt with a hammer,
from time to time.
A couple of belts, well taps realy, with the end of a 3 Ft lump of
2x1, had the starter suitably cowered, & the engine running happily.
But will it go, tomorrow?
So, what I want one of you clever people to do, is tell me what I
have done. What part of the starter motor of a late 4.6 Range Rover
engine, would respond to my belting it? What should I plan to have
fixed, before it leaves me stuck somewhere?
ngtf
Postby ngtf » 04 Nov 2007 13:41
Hi Hasbeen
It sounds like it could be the solenoid, I certainly like the temporary fix though. I have looked through all my specialist parts for Triumphs but cannot find a piece of timber 3feet long and 2"x1" in profile. Have you possibly got the part number!! [:D]
Hioe the car goes well after the work on Tuesday.
Cheers....Gary
Eeyore rides again !!
Postby Rich in Vancouver » 04 Nov 2007 15:10
I think that you will find that under a Lucas number![:D]
Launie
Postby Launie » 04 Nov 2007 17:00
Almost a certainty that it is the starter solenoid. Might keep going for a while, but is undependable, for sure. We used to take it apart and turn the contact point 180 degrees to use the other "rivet" as a contact point. The cause of intermittent failure is that the contact point tends to get burned away due to arcing. That is why a tap (a wrench is as good as a chunk of lumber) will "adjust" the contact a bit, albeit often for that occasion only.
Better solution is to replace the solenoid or get a rebuilt starter, usually equal in price these days. Although you might travel around with the lumber at hand to be used for those bad starts - at least unti the solenoid quits for good.
Launie
Postby jclay (RIP 2018) » 04 Nov 2007 17:15
Mine started having the dead key fear. Most of the time, everything was fine, but then you would turn it and nothing would happen. Then I got to where things were not happening more than they were happening.
It was a rebuilt starter that I had installed last summer when I had the transmission out. I put the original starter back in and have had no problems ever since.
I would go with the smaller high torque units and probably be done with the problem.
Postby Underdog » 04 Nov 2007 17:30
I went the gear reduction unit route on mine after a couple of emergency push starts were required. The one I bought came with a shim kit. I found that it required one of the shims to keep the drive gear from dragging on the ring gear. Works great & sounds kinda neat on crankover.
