TR7 2l ACCELERATION PROBLEMS
Misty40
Postby Misty40 » 12 Oct 2007 10:15
Can anyone offer any advice please......
My Inca Yellow FHC TR7 has recently had original seats fitted and sadly we experienced a bodge job which resulted in some brut force being needed to remove the old seat. Since then my poor baby has developed acceleration problems.
He will idle perfectly well but sadly after a while when being driven it will not accelerate and coughs and splutters.........on the odd occasion it will also backfire and there is a strong smell of fuel.
We are not sure if muck in the fuel tank has been disturbed due to the removal of the seats which has now blocked the jets.
If anyone has any suggestions I would be very grateful as I love to use my TR7 on a daily basis weather permitting of course.
Hope to hear from someone very soon [:)]
Jolyon39
Postby Jolyon39 » 12 Oct 2007 21:36
My car had similar performance problems once so I will relate my own solution to you. I doubt that being violent with the seats did damage though as hard braking etc will slosh the fuel around far more than that. Maybe the pounding shook off more rust?
My car is a 79 DHC imported from the UK. When I smelt fuel I found that the rubber fuel lines were original and had rotted over the 27 years that car had been running. Replace them at both in the engine bay and at the tank sender unit.
The surging , spluttering and loss of power that you describe sounds exactly like the problem I experienced. The level of water, rust and other unidentifiable crud in the fuel tank had reached a point that meant it was sucked up into the fuel lines, filled the float bowls and did the nasty to the needle and seats.
Putting a fuel filter on the line will last a minute before you have to install a new filter so don't even think of it. You can open the tank via the sender unit opening and syphon out quite a bit of the crud but this is a temporary fix, your tank is probably going to leak soon anyway, they all do.
My solution was to remove the tank, the dirtiest job in the whole car, have it reconditioned and reinstall it. During this process it is a fantastic opportunity to clean up rust on top of the rear chasis legs, install new trailing arm bushes, new bushes in the tie rods and even new bushes in the little handbrake pivot lever. This little lever gums up and makes your handbrake less effective so scrub it clean an install the new bushes.
You will need to flush your fuel line and strip the carbs.
There is a huge history of threads here on how to remove your tank Because we all have to fix this at some stage. You will find all the tips and tricks for this on those old threads.
Jolyon
Postby John Clancy » 13 Oct 2007 09:28
Misty40, the way to diagnose if it is the fuel tank is to run a length of fuel line from the fuel pump into a jerry can. I did this a few times recently with a 2 meter length of pipe (cost about £5) and ran the pipe out the back of the bonnet (didn't clamp it shut for obvious reasons), in through the drivers window, and sat the jerry can under my legs. I then went for a short test drive to see if the misfiring had been cured. It had, so I syphoned the remaining contents out of the tank. What a mess!
If you get to the point of pumping out the tank make sure you drain enough of it off via the fuel line before knocking out the sender unit. I jacked the car up at the back and drained it from the pipe connected directly to the tank. Then when I knocked out the sender nothing else came out leaving me to just syphon with a £2 hand pump from the local motorist shop.
Users browsing this forum: No registered users and 106 guests
