New Servo Brake light on allthe time
bonnietiler
Postby bonnietiler » 11 Dec 2016 18:05
Hi Guys just fitted the new servo...got to be honest don't much like the "feel" of the brakes now, a bit wooden..very light but manufactured at the Mahogany plant if you catch my drift ...But I removed the brake switch from my old servo (genuine TR7) and fitted it to the new (Rover Rimmers) jobbie as the wiring would be slightly different.However..my brake lights are now on permanently,I'm assuming that this is the problem?
Can anybody advise?
Bonnietiler
Spike
Re: New Servo Brake light on allthe time
Postby Spike » 11 Dec 2016 19:04
If you did anything like I did when I fitted mine, you've probably bent the bracket that holds the light switch a little. All you need to do is bend it back slightly so that the switch is resting on the peddle.
bonnietiler
Postby bonnietiler » 11 Dec 2016 23:53
Thanks for that I shall have a looksee tomorrow
Bonnietiler
bonnietiler
Postby bonnietiler » 12 Dec 2016 12:44
Exactly as you described...all my own work!
Thanks for the headsup made it an easy fix
Bonnietiler
