tr7 v8
greasemonkey
tr7 v8
Postby greasemonkey » 29 Oct 2016 08:34
hi all,first post so i will tell you a little about me and my car,i am a semi-retired motor trader/garage owner.my car is a 1977 FHC originally an LHD export car.i bought it in 1990 from a chap who had converted it to RHD.i fitted the engine and gearbox from a SD1 V8S rover.the diff came from a SD1 V8 automatic.the conversion was carried out mainly with parts modified by myself and some rimmer bros TR8 parts.having two young children at the time i also carried out a 2+2 conversion which involved cutting out the rear bulkhead and fabricating a rear seat pan and using a modified renault 18 fuel tank and some fold forward toyota MR2 leather seats.i intend to do some more work on the car this winter and would like to call on the forums collective knowledge as i go,cheers greasemonkey..
Brianc
Re: tr7 v8
Postby Brianc » 29 Oct 2016 08:49
Hello and welcome.
Im relatively new here. - 12 months or so, but have found the forum to be really helpful.
I also have a v8 that was converted by s&s and its great
Where in the uk are you
greasemonkey
Re: tr7 v8
Postby greasemonkey » 29 Oct 2016 09:06
hi,i live just outside bedford [UK].i am considering fitting a four barrel carb setup as i have never been happy with the twin SU's.the engine has a slightly raised compression ratio and a higher than standard lift camshaft.some say fit the holley carb,others the weber/edelbrock,any advice on this would be much appreciated,cheers greasemonkey..
Tamas Petrunin
Re: tr7 v8
Postby Tamas Petrunin » 29 Oct 2016 10:01
All the lads I know with V8's in their Tr7 have gone the Webber/Edelbrock route, they all say it's a lot easier to change the jets etc to get them running spot on than with the Holley. They all get around 30 mpg on a long steady run. I only get high 20's but then I'm running twin SU's at the moment.
I was going to follow them down the Edelbrock route but since I like messing with electronics I've decieded to go fuel injected instead, hopefully I'll get that done this winter.
Cheers TP
Re: tr7 v8
Postby busheytrader » 29 Oct 2016 20:41
Any photos of your 2+2 interior Mr Monkey?
greasemonkey
Re: tr7 v8
Postby greasemonkey » 29 Oct 2016 22:33
hi,would love to show you some pics of the conversion but the beast is in my storage building at the moment hemmed in by my motorbikes.when i move it to the workshop to do some work on it sometime in the next few weeks i will take some pics of the seats etc and put it up on the lift and take some of the underside and then put them up on the forum,cheers greasemonkey
seven
Re: tr7 v8
Postby seven » 09 Nov 2016 17:26
Good to hear of another V8 TR7. 8)
I also know what it is like to have your car hemmed in :lol:
My V8 conversion is also SD1 but with fuel injection, its been a long project, though I spend as much spare time on her as possible.
Look forward to the pictures :wink:
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
Rich K
Re: tr7 v8
Postby Rich K » 09 Nov 2016 17:46
Hi, I am in a similar position as I have come by a 3.9 V8 engine with gearbox and axle to fit into my 1980 2 litre drophead. The engine came with all the fuel injection bits/ECU but as I have no experience with FI I am considering going down the 4 barrel Webber/Edelbrock or Holley carb route.
Rich.
Ford Ranger Wildtrak
Jaguar XKR Supercharged
seven
Re: tr7 v8
Postby seven » 09 Nov 2016 18:05
I too have very little experience with fuel injection, I just blunder my way through fitting the wiring into mine and as it was basically a swap from one car to another I was able to get it running with some help from someone who had some experience in the field of auto electrics.
Fuel injection is far superior in my view and as I have raced fuel injected cars against carbed models the injection sure has the edge........But obliviously this is my own point of view and the injection system does need to be in top form :)
Triumph TR7 DHC '81
Mercedes E320 '05
Re: tr7 v8
Postby Hasbeen » 10 Nov 2016 02:42
I love everything about the SUs on my 7. Wouldn't change them for the world.
I would not consider running the 8 on anything but a fully tuneable computer controlled fuel & ignition system after my recent experience of how easy it was to fix my overheating, with a few clicks on the lap top.
Re: tr7 v8
Postby john 215 » 10 Nov 2016 07:33
Sounds an interesting car, will have to look out for you out and about, live down the A6 from yourself in Luton.
I have run both carbs, the Holley work better out of the box, the Weber is set too rich for a 3.5 but its no big hassle adjusting the needles and jets ect. Got a weber on my 4.6 and happy with it.
