Hello, My Son's TR7, worked fine up until about 45 minutes ago..He parked it at the top of the drive turned the starter and Nothing not a peep..everything electrical works, with the ignition turned on. Not so much as an attempt from the starter.
Removed the Relays and replaced still nothing although I think I can hear a slight "click" when the starter is turned?
Battery is new tried pushing it in gear in case the motor has jammed and it starts beautifully from a push start no problem at all.
Any ideas?
Bonnietiler
