Switch telltales
Switch telltales
Postby saabfast » 30 Apr 2016 22:10
The day after I left the country for 3 weeks Storm Katie hit (maybe lucky as it closed the airports). The storm pulled the cover off the car in the driveway although it was replaced by my son and neighbour after the storm. When I got back I noticed that the headlights were up and the battery completely flat (I have a CTEK on it but that cuts out below about 7 volts). Somehow the rain seemed to have got into the electrics (the footwells were full too) and lifted and switched on the headlights. I tried to drop the lights using the manual knobs, only to find that the nearside one did not have a knob! I put a good battery on, checked the connectors behind the lights, switched on the lights and they did the well known dance (not in synch) and stopped, then started again and synched themselves. All seemed OK but I decided to strip and clean the switches to make sure.
The telltales in the fog light and hazard switched always give trouble, normally needing much prodding and pulling of wires to get them working long enough for the MOT. Cleaning the switches did not cure this problem (they were not bad inside). I then pulled and checked the peanut bulbs, all OK, so I tried pulling out the contact wires which run along the side of the glass to make better contact with the brass strips in the connector block. This seems to have cured the problem and they now work every time, so if you have these problems the solution is simpler than rebuilding/replacing the switches.
Still have no idea how both lights raised and switched on with the light switch off though!
Dave Dyer
Re: Switch telltales
Postby Dave Dyer » 01 May 2016 11:13
Hi Alan,
Thats a strange one about the lights.
But when I had my first TR7 back in the 1980's (and knew very little about working on cars) it came without a Radio, just a hole waiting for one to be fitted and in those days it was the first thing everyone seemed to do- fit a Stereo radio or Radio Cassette if you could afford one! But I had to wait and save up, But anyway there was a live wire in there taped up (I can't remember what it was for, maybe feed for Radio) but the tape fell off and the wire decked down to earth and this caused the headlight to raise! Why I don't know. So I showed everyone at college and nobody could come up with an answer!
Electrics are a strange thing in a TR7 and adding water caused the problem you described, but its definately a head scratcher!
Dave
Postby saabfast » 01 May 2016 14:55
Spoke too soon, took it out for the first runaround of the season this morning and checked things, hazards are fine but the fog light telltale has stopped working again. Well, it is a TR7! :roll:
Users browsing this forum: No registered users and 71 guests
