shifter is a bit cantankerous...
JamesH
Postby JamesH » 07 Apr 2016 22:03
...on my pretty-stock 1980 TR7 drophead. it is the 5 speed. i have read of these getting sloppy in the shifter from deteriorated rubber bits where the shifter attaches to the box, so i picked up a new set of those bushings, but it occurs to me that my problem isn't that it is sloppy and loose it is that the gears are hard to find sometimes and you have to be very precise to get the shifter to slot in. anybody have a thought about this?
Triumph TR7 drophead 1980--driver
MGB GT 1972--driver
International Scout 4x4 1963--driver
MGB tourer 1977--project
MG Magnette ZB 1958--project
MG Magnette IV 1963--project
Opel Kadett wagon 1968--project
Porsche 914 1975--project
darrellw
Re: shifter is a bit cantankerous...
Postby darrellw » 08 Apr 2016 00:13
One test is to pull up on the shifter, if it lifts up then your bushings are shot. I think it could still be your bushings, with the shifter extension flopping around, its relationship to the shift lever is kind of random.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby dursleyman » 08 Apr 2016 01:13
If the extension is moving all over the place because the rubber bushes are shot then its likely you will have all kinds of trouble finding gears. I would fix them first then you will see if there is any other problems with the box.
Postby john 215 » 08 Apr 2016 06:41
IF bushes are shot, which sounds very likely, replace them with Poly bush type, these will outlast the rubber type by years.
sonscar
Postby sonscar » 08 Apr 2016 13:03
Google LT77 gearlever adjustment or look in the manual and follow the instructions exactly.It is very time consuming and fiddly to do with some dismantling but if the bushes are good will pay handsome dividends.I have done this with two LT77 equipped cars and it transformed the gear change.Steve.
Postby FI Spyder » 08 Apr 2016 15:50
On mine, when I bought it, it had no bushings left. It was like stirring porridge. New poly bushings firmed it right up. Still notchy/hard to shift into 2nd when cold (feature of the LT77). The correct oil to match the requirements of the syncros fixed that. The only thing left to do is adjust the gear shift springs so it is a bit more definitive in the neutral slot (tired 36 year old springs).
Postby Beans » 08 Apr 2016 18:06
JamesH wrote:... my problem isn't that it is sloppy and loose it is that the gears are hard to find sometimes ...
Agree with Steve, but first check spring on top of 'box extension and after that make sure the lever is adjusted properly.
The spring should align the lever with the plane for 3rd and 4th gear.
Postby busheytrader » 08 Apr 2016 19:16
As you already have a new set of bushes, fit them first before making any other adjustments with the gear lever spring..........otherwise you may have to reset them afterwards.
Postby Hasbeen » 09 Apr 2016 03:18
Just to play devils advocate, when I got my current 7 going, the gear change bushes were almost nonexistent, as they have been in all my 7s. However the gear change was as smooth as silk & quite precise.
I had probably done a couple of thousand kilometres in the car before I got to the extension bushes. After they went in the change was equally precise, but was stiffer to use. Not unpleasantly so, it was still a beautiful gear change compared to most, but not quite as sweet. It went from a 2 finger change to a 4 finger change.
70,000 kilometres & over a decade later the change is still the same 4 finger change, & equally satisfying. The selector spring did loose some tension, & was allowing the leaver to move over into the reverse plane too easily. You should have seen the look on the face of the technician at the large spring makers, when I asked them to retemper my little hair type spring. It worked though, now I no longer have to be careful not to go too far & into the reverse plane, when going back to second in anger.
