gearbox mount
titan
gearbox mount
Postby titan » 22 Mar 2016 19:09
hi, putting in a TVR engine soon and have noticed that the LT77 box has a different mounting. The usual type is single rubber but the one i have is a double at an angle. Does anyone have a drawing or photo before i go hacking the cross member to bits .....................thanks
Re: gearbox mount
Postby busheytrader » 23 Mar 2016 23:52
I think you're after something like the arrangement in the Rimmers link. It sounds like you have something similar to the SD1 which used the same gearbox but 2 mounting rubbers on a very different crossmember.
http://www.rimmerbros.co.uk/Item--i-GRID006415
The V8 crossmember isn't available but the TR7 item can be used.
There's someone selling on eBay
http://www.ebay.co.uk/itm/TR7-Gearbox-m ... Sw2ENW7afB
Hope this helps,
whitenviro
Re: gearbox mount
Postby whitenviro » 24 Mar 2016 01:35
There has been a lot of discussion about the gearbox mount and finding comparable replacements because the new reproduction mounts are very hard rubber and transmit a lot of noise up into the car. What does the TVR mount look like? Is it at all adaptable to this kind of cross bar?
Re: gearbox mount
Postby Hasbeen » 26 Mar 2016 09:23
One of my 7s had 2 small round mounts on either side of the box. A Triumph expert said they looked like Stag mounts.
It really was a pretty good car with a great body, but was really gutless 7 required more work than a couple of others I had, so I moved it on, without ever looking much at that mount. Wish I had now.
Hasbeen.
titan
Re: gearbox mount
Postby titan » 26 Mar 2016 12:28
HI, thanks for the replies. Trying to adapt this arrangement to a std mount.
LT77 gearbox mount.jpg (155.37 KiB) Viewed 4093 times
sonscar
Re: gearbox mount
Postby sonscar » 27 Mar 2016 08:54
Good old MGB mount.I have the same thing on my MG and it is very good,worth copying.Steve..
