sticking ignition key, what gives?
JamesH
Postby JamesH » 22 Feb 2016 01:06
getting the ignition key to turn the last click to the "removal" position has been difficult since i got the car...a whole week ago...but yesterday it took 10 minutes of fiddling to get it to come out at all. the pad on my right thumb is a little bruised from the exercise. i tried pushing it in, but there really isn't any sensation that it pushes in. i hit it with graphite powder last weekend and yesterday i hit it with penetrating oil to get it loose. i am afraid that it eventually just isn't going to come loose at all. the parts suppliers i use most for MG parts both have Triumph as well and both carry the switch and pigtail, but not the lock cylinder. any ideas about this? is the problem in the switch and i just need to get a new one or is it the lock cylinder and so what do i do? thanks.
Triumph TR7 drophead 1980--driver
MGB GT 1972--driver
International Scout 4x4 1963--driver
MGB tourer 1977--project
MG Magnette ZB 1958--project
MG Magnette IV 1963--project
Opel Kadett wagon 1968--project
Porsche 914 1975--project
supercass
Re: sticking ignition key, what gives?
Postby supercass » 22 Feb 2016 20:22
Just an off chance, try wiggling the steering wheel when you attempt to remove the key. If the steering lock is on it may possibly be difficult, usually to move the key to the start position. supercass
Postby Hasbeen » 24 Feb 2016 08:55
The ignition keys in Oz 7s will not turn to the removal position from the off position. You have to turn the key to the on, engine run position. At this position it will push in further, allowing it to pass the lock to the removal position.
JamesH
Postby JamesH » 25 Feb 2016 01:31
Hasbeen, Eureka! thats it. i had tried pushing the key in, to no avail, but didn't realize that i needed to try it from the "on" position, as opposed to the "off" position. quirky. so, i went out and tried it and this mystery has now been solved. thanks, man.
MGB GT 1972--driver
