the wheel TR5
syol
the wheel TR5
Postby syol » 17 Feb 2016 04:50
Hi !
tr5 the wheels is that what it mounted on a tr7?
thank you
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
3 tr7 DHC 2.0 L 1980
TR7 FHC and sunroof 1981
http://www.tr7.fr
Re: the wheel TR5
Postby Cobber » 17 Feb 2016 05:55
No, TR-7s have a different PCD, spigot and offset to earlier TRs
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Re: the wheel TR5
Postby FI Spyder » 17 Feb 2016 15:03
MGF had same wheels, Spitfire has same PCD but smaller lugs, some Lotus had same wheels size. Don't know about others but it wasn't a common size which is why it's difficult to get a variety of wheels. Some manufacturers produce a blank alloy wheel and the number of lugs, PCD, lug size can be custom drilled according to application.
syol
Re: the wheel TR5
Postby syol » 17 Feb 2016 18:51
Thank you for reponse....
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
