SISA wind deflector
Brianc
SISA wind deflector
Postby Brianc » 13 Dec 2015 16:14
Does anyone have one of these fitted?
I bought just the perspex and aluminium strip, but this came without any of the other brackets and fittings.
SISA want 100 euros for these fittings !!!!! If anyone has one of these deflectors I'm wondering if they could provide me with dimensions/diagrams of the fittings. Im sure i could fabricate some cheaper !!!!
Thanks in advance
Brian
Re: SISA wind deflector
Postby dursleyman » 16 Dec 2015 15:09
Brian, just spotted this post. I have a perspex deflector but I bought it secondhand so don't know the make but this is how the mounting looks.
There is a flat plate under the seatbelt fitting with the part shown upright in the photo. There are then two "L" shaped pieces of steel that slot into the mount and into the aluminium rail of the deflector.
I can take some more pictures if you need them.
Brianc
Postby Brianc » 16 Dec 2015 15:50
Hello russ
Thanks for getting back to me
I think its the same as mine, which is great!!!!!
Can you do so e more pictures, particularly of the bracket which fits onto the screen itself.
If you wish, you can send them to my email, which is briancrook@ blueyonder.co.uk.
Im sure i can fabricate some of these rather than pay 100 euros !!!!!
Many thanks.
Brian
Ps are you in northwest?
Postby dursleyman » 18 Dec 2015 17:00
I'll post some pictures here so then everyone can see them in case its useful.
Its all on the car at the moment and a under a dust cover in the garage but I can easy take some more snaps.
Watch this space.
Postby dursleyman » 29 Dec 2015 15:53
OK here are some more pictures which I hope will explain better how the wind deflector mounts. See post above for the bracket which fits under the seatbelt reel.
Installed position 1
Installed position end view.
Shown half installed for clarity
Final position. The small hole is for a plastic peg to lock in position and make sure it doesn't fly off at speed!
Brianc
Postby Brianc » 29 Dec 2015 16:41
Thanks russ - im sure i can fabricate some of those.
Many thanks
Brian
Postby Hasbeen » 29 Dec 2015 23:39
Went for a drive with my son in the 8 last night, him driving.
I did notice I was getting more breeze from behind than I do in the S2000 with it's deflector up, while driving to the main road.
However, once out of speed restrictions & he hit me in the back with all 330 BHP in second, all thoughts of where any wind was coming from were obliterated. This car with it's mew manual gearbox really is brutal when driven hard. Even the retardation from engine braking is heavy. It is no longer a car to impress most ladies.
So, unless you wish to please ladies, you could add a hundred BHP, & have all thoughts of wind deflectors driven from your mind.
Haswbeen
Postby dursleyman » 30 Dec 2015 12:33
Hasbeen wrote:Went for a drive with my son in the 8 last night, him driving.
Haswbeen
If there was a "LIKE" button I just clicked it.
Howard_B
Postby Howard_B » 31 Dec 2015 15:48
On my wind deflector there is a blast of air that comes through the gap between the deflector and the body. I cured this by using pipe insulation - it fits in the gap nicely and made of black neoprene it doesn't look too bad either
Happy New Year to everyone
Howard
supercass
Postby supercass » 01 Jan 2016 11:45
Looking at the photo's, if you are going to make new brackets I wonder if the screen needs to be raised at all. I think it would be far easier to make straight brackets that do not bend upwards at the side of the seat belt mounting. This would mean no space or very little space for draughts at the bottom of the screen. This would mean that the method of attachment to the brackets would need to be given some thought unless you wish to remove and re fit a seat belt reel everytime you fitted the wind breaker. supercass
mb4tim
Postby mb4tim » 11 Feb 2016 19:32
Here's how mine attached. For some reason,I can't see any photos in this topic.
The plate goes under the reel, then a thumb screw attaches the shields to the place. The whole unit stays in place when raising or lowering the top.
Postby FI Spyder » 12 Feb 2016 15:22
Although a different blocker (BMW Z3) my attachment is similar in concept to Tim's. The shape was determined by not wanting to drill any unnecessary holes. I used the BMW brackets up side down and an Allen wrench undoes a long screw holding the blocker to brackets, easily removed at those times when you want to stow the blocker in the trunk (when parked overnight in unknown street location). Because the blocker is hinged it can be folded down flat on the carpeted shelf when the top is up. It could sit 1" to 1 1/2" higher as the wind still catches the hair at my ride height which may necessitate some material at the bottom to prevent drafts underneath. A problem I will address when I have the time to do so (I have it pencilled in before my 80th birthday :? ). The only other tweeks would be to reinforce the stainless brackets as they wobbble a bit. The blocker is a bit narrow as the Z3 is a narrower car (remember the TR7 cockpit is wider than a Corvette) but I can't say it affects the side draft, won't really know until it's raised.
Brianc
Postby Brianc » 12 Feb 2016 21:23
Ive given up with my idea to fabricate my own brackets and havecprdered a set frpm sisa sp we will see
