Gearbox oil pump
Loltr
Gearbox oil pump
Postby Loltr » 26 Nov 2015 03:50
Does anyone know if there is a way to test if the LT77 oil pump is working. I have replaced fibre gear with uprated metal oil pump gear. However the gearbox has a rumbling noise when the car has been run for a while and the oil is hot. more noticable when gearbox is operating in overun. All gears operate smoothly (hot or cold) and Gearbox does not make a noise when cold. I am using Castrol VMX80 manual gearbox oil.
I seem to remember that there is a procedure for testing operation of oil pump.
Your help is very much appreciated.
:lol:
Re: Gearbox oil pump
Postby Hasbeen » 26 Nov 2015 10:59
There is a screw in plug in the bottom of the box, usually half hidden by the gearbox mount.
To test the pump you screw this plug out, & run the engine. A small amount of oil will be pumped out of the passage, showing the pump is working.
Hasbeen.
Users browsing this forum: No registered users and 30 guests
