I'm removing the electronic module along with the distributor an Electronic Delco unit. Car is a federal spec import from the USA, a TR7.
I have fitted a standard distributor with points again a Delco unit, unfortunately my wiring loom doesn't have the ballast resistor cable,
so I need to fit a ballast resistor, in order not to burn out the coil, can anyone tell me where I can get one for the TR7, S and S in Bacup didn't have one, are they all the same
and could a motor factor supply one?
regards Peter.
