Strange Screw Head
jaybee
Strange Screw Head
Postby jaybee » 05 Jul 2015 19:55
Please can anyone tell me what kind of screw this is? It is part of the dash assembly. I must have a hundred screw bits. Never seen one like this!
2015-07-05 19.51.09.jpg (64.99 KiB) Viewed 6573 times
1981 FHC in Pimento Red.
Re: Strange Screw Head
Postby UKPhilTR7 » 06 Jul 2015 03:40
I know that it looks a strange one, but I was able to loosen and tighten mine with a normal small flat head screwdriver. It took a bit, but I was able to do it.
Postby Cobber » 06 Jul 2015 04:21
Unfortunately the pic isn't at a high enough resolution to get a good look, it looks a bit like a place bolt, which is a special type of bolt which is used on rotating assemblies such as flywheels and diff crown wheels ( I'll not try and explain how these work, it'd take pages) but there is no reason why you'd use one of those on something like a dash.
Could you take a better pic? preferably with something else in the pic to give an idea of size such as a pencil.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
sonscar
Postby sonscar » 06 Jul 2015 07:58
There are used in the instrument cluster and I used a screwdriver with an indent filed in the centre to remove them.Steve
jaybee
Postby jaybee » 06 Jul 2015 09:29
Thanks guys. You know the feeling. You start a simple little job!
Postby dursleyman » 06 Jul 2015 09:43
I have always been able to undo them with a flat blade screwdriver. You can always replace them with a "normal" pozi or phillips type screw afterwards if you need to.
jaybee
Postby jaybee » 06 Jul 2015 21:02
Got em out! Thanks guys
Postby UKPhilTR7 » 07 Jul 2015 03:33
jaybee wrote:Thanks guys. You know the feeling. You start a simple little job!
I have always found these jobs to be the worst. You go to the garage thinking it will be a simple job and end up being there for hours :D
It is good that you got them out though and I would certainly think about replacing them.
jaybee
Postby jaybee » 07 Jul 2015 08:10
Most definitely . I'm replacing the clock with a battery one so easy access is required at least twice a year.
Postby andyf » 07 Jul 2015 13:00
Top of the instrument cluster. Again, I have found them simple enough to undo and re-tighten with a normal largish flat blade screwdriver.
1980 Persian Aqua DHC
navydiver
Postby navydiver » 09 Jul 2015 23:15
a 12 point socket usually works as well.
Rob Cornick
1975 TR7 FHC Ca Spec ACL 4 spd
1977 TR7 FHC ACW 5Spd
1978 TR8 FI DHC ACT 5spd
1980 TR7 FI DHC Spider
1980 TR7 FI DHC
seven
Postby seven » 12 Jul 2015 10:03
Page 10 and about 1/3rd the way down on my blog page has a good example on how to remove these screws in record time, oh and to refit them :wink:
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
John_C
Postby John_C » 12 Jul 2015 14:10
Is it just me who has the correct screwdrivers to undo all these little dash screws? I bought a pack full of screwdrivers with these strange heads for very little money.
www.triumphdvd.co.uk
jaybee
Postby jaybee » 12 Jul 2015 15:21
I got them undone and replaced them all with ordinary screws. See my post on Battery Clock.
Postby dursleyman » 12 Jul 2015 21:12
John_C wrote:Is it just me who has the correct screwdrivers to undo all these little dash screws? I bought a pack full of screwdrivers with these strange heads for very little money.
Where?
Users browsing this forum: No registered users and 16 guests
