Clock fixes please!
jaybee
Clock fixes please!
Postby jaybee » 01 Jul 2015 14:23
Hi Guys the clock doesn't work in my 7. I believe this is very common. Any fixes please? Perhaps from another car etc.
1981 FHC in Pimento Red.
whitenviro
Re: Clock fixes please!
Postby whitenviro » 01 Jul 2015 14:46
A stopped clock is right twice a day. But since the TR7 clock sometimes works but doesn't keep time well, it is most likely less accurate than a stopped one would be.
I think a lot of people on here would tell you to replace it with an oil pressure gauge.
jaybee
Postby jaybee » 01 Jul 2015 15:01
Ha ha yes I've considered that. I'm wondering about fitting a cheap battery clock movement in there.
Postby FI Spyder » 01 Jul 2015 15:22
My clock always works and is pretty accurate (reset it about once a month). Some people find cleaning the contacts on the clock/wiring is all it takes to get it running reliably (like anything else on the car). There is a capacitor modification that can be made (never found it necessary) to make it more reliable (the link should be in the archives, search).
jaybee
Postby jaybee » 01 Jul 2015 16:49
Not removed it yet but obviously will try to make it work first.
seven
Postby seven » 01 Jul 2015 17:11
I have had a few TR7's and none of the clocks worked, though I never tried to make them work or investigate why they didn't work, but when I put a battery on Ruby after being off the road since 1986 the clock works perfectly :shock: :lol:
Sorry I am not much help to your question :oops:
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
jaybee
Postby jaybee » 01 Jul 2015 20:09
Not at all. It just confirms they were rubbish clocks!
TonyS
Postby TonyS » 01 Jul 2015 21:41
From the comprehensive files inherited from the previous owner of our TR7V8, it seems that you can send the clock to an electronics wizard in the USA for modification as was ours. I can confirm that the clock works perfectly.
Alternatively, have a look at this resource if you fancy having a go yourself! :lol:
(It also includes details of where to send your dicky ticker)
http://www.littledoggarage.com/Articles/TR78clock.pdf
Postby saabfast » 01 Jul 2015 22:02
You could try disconnecting the battery then touching/flashing the battery terminals. The jolt has got my clock working once or twice. It normally seems to stick after the battery has been disconnected for a while, a quick jolt gets it going again.
jaybee
Postby jaybee » 01 Jul 2015 22:51
saabfast wrote:You could try disconnecting the battery then touching/flashing the battery terminals. The jolt has got my clock working once or twice. It normally seems to stick after the battery has been disconnected for a while, a quick jolt gets it going again.
I'll certainly try that! Thank you
seven
Postby seven » 02 Jul 2015 08:53
That certainly was an interesting thread on the clock TonyS.
I have been told that on some printed circuits small diodes break free from their solder bases and through that everything seems to stop working. A good few years ago in my modern the heater back light failed. £525 from Renault to replace the heater display :shock: I found out through a contact that all it was, was a solder joint come unstuck, I removed the heater display panel and located the solder joint and just dropped some more hot solder onto the spot, and hey presto light worked for ever more :lol:
This was such an achievement for me especially with my auto electrical record!!!
Triumph TR7 DHC '81
Mercedes E320 '05
jaybee
Postby jaybee » 02 Jul 2015 12:36
It's always worth having a go. I had a similar thing with my MG TF heater resistors . Soldering iron saved a fortune
sonscar
Postby sonscar » 02 Jul 2015 18:17
My clock worked erratically sometimes for days other times for minutes.Looking at it for the 50th time I decided there was nothing to lose now so I gave it a good soaking in GT85(other sprays are available)as I was informed the PTFE in it would lubricate it.Six weeks on and it is still working.Steve...
Postby nick » 02 Jul 2015 18:50
Took mine apart and found a broken part in the mechanical works. In the process of trouble shooting I found you could use a 9v battery to power the electrics making that part pretty easy. I gave up on it after a bit of fiddling and found a new one on ebay for about $40.
Sometimes that light weight circuit board that powers the dash items has wire breaks which will cause loss of power to the clock. Be sure you check that when you get in there.
'79 TR7 DHC
'76 TR7 FHC
TonyS
Postby TonyS » 02 Jul 2015 21:22
