Hazard switches-early and late--Q?
Howard722
Postby Howard722 » 29 Jun 2015 18:20
There are two styles of hazard switch.
Early has the triangle symbol on the slider button, later has the symbol on the warning light--BUT are they interchangeable i.e is the the plug in part the same for both? :?
Enjoy & regards
seven
Re: Hazard switches-early and late--Q?
Postby seven » 29 Jun 2015 19:51
I have two hazards switches, one from a 1977 car with the triangle on the switch and the other is from a 1981 car and it too has the triangle on the switch, both of these are interchangeable in the two different wiring looms I have, so there is a good chance that the will plug in to the same wiring?
Cheers Peter
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Fiat Ducato Motorhome '03
Howard722
Postby Howard722 » 03 Jul 2015 07:28
As both your switches are the early type (from your description) doubtless they would fit either of your looms-question is--would the later switch (triangle on the lamp) also fit and function correctly? I think the later switch is probably used from 1982 on. :?:
Enjoy & regards
seven
Postby seven » 03 Jul 2015 12:00
Howard722 wrote:As both your switches are the early type (from your description) doubtless they would fit either of your looms-question is--would the later switch (triangle on the lamp) also fit and function correctly? I think the later switch is probably used from 1982 on. :?:
That I am unsure of, it looks like both my cars were the early versions ('77 and '81 use the same switch) I should have thought that Triumph weren't in a good financial position at the time to go to the expense of changing a switch and having the wiring loom to the switches altered? My guess would be that the switch was from a different supplier at the time that was cheaper than their previous supplier (somebody was thinking 'savings')!! But it still had the same fitting to fit the existing loom? Well that's my logical way of thinking :lol:
But then I have been known to be wrong......Many times :roll:
Triumph TR7 DHC '81
Mercedes E320 '05
Users browsing this forum: No registered users and 16 guests
