Don't think this is doing anything
Postby UKPhilTR7 » 21 May 2015 00:28
The other day, whilst replacing my relays, I notices an earth cable, that I do not think is doing anything. As it can be seen from the picture below; it comes from the bolt on the coil holder to the suspension strut bolt. I may be wrong, but I do not think this is serving any purpose and therefore I was thinking of taking it out. Would you agree?
whitenviro
Re: Don't think this is doing anything
Postby whitenviro » 21 May 2015 00:59
If it ain't broke...
darrellw
Postby darrellw » 21 May 2015 02:58
I agree, it doesn't appear to be doing anything.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby UKPhilTR7 » 21 May 2015 03:33
That was my thought too, that it is not doing anything. If it was coming from a coil connection then possibly, but as it is going from one earth point to another, then the wire is useless.
Postby REPLIC8 » 21 May 2015 07:01
Mine has the same wire, it's factory fitted. No idea what it's for.
Postby andyf » 21 May 2015 07:46
Likewise, and I have always wondered what on earth (sorry) it does. But as whitenviro says, if it ain`t broke..
1980 Persian Aqua DHC
Maki
Postby Maki » 21 May 2015 08:23
I think these had a suppressor for the radio attached at one time, mine had one on when I bought it back in 1987 it is still there now. if I can figure out how to upload an image I will!
toneinblack
Postby toneinblack » 21 May 2015 08:47
Take it off and see what stops working :)
Postby dursleyman » 21 May 2015 10:56
The one on mine was attached under the pressure limiter bolt rather than the strut top - same difference though, it didn't seem to do anything so I left it off.
Postby FI Spyder » 21 May 2015 15:00
I think it's a backup ground to drain any electrical charge build up on the coil. It is also on my Delco coil/amplifier. Will your car stop working if you remove it. No. But you shouldn't.
Postby UKPhilTR7 » 22 May 2015 03:46
Should it stay or should it go lol.
I like the quote about take it off and see what stops working. Not much works sometimes, so may be hard to find :D
Stag76
Postby Stag76 » 22 May 2015 04:57
It's connected to the chassis (ground) at both ends, so it's doing nothing.
Probably something to do with the proposed fitting of a Flux Capacitor or Energy Polarizer.
Postby john 215 » 22 May 2015 06:54
I remember Austin Aggroes ( Allegro ) I think only the E series ( 1500 and 1750 ) had a similar wire doing the same thing ie. nothing ! No doubt kept someone in a job somewhere !
