New Battery positive cable
Dave Dyer
Postby Dave Dyer » 25 Jan 2015 11:25
I'm making a replacement battery positive cable, the one that connects between the battery and starter motor.
But the problem is, normally there are 2 brown cables that attach via 2 large spade connectors, these brown wires supply the rest of the car with power. I've looked into removing the connector from the old cable, but it has been machine crimped in and I can't remove it or reattach to new cable.
I'm at a loss what to do?
I'm hoping some of you have come across this and have a solution?
Thanks,
Dave
Postby john 215 » 25 Jan 2015 11:39
Hi Dave,
How about soldering on a couple eyelets and connect straight to battery positive. I done similar when relocated the battery to boot on my DHC, but connected to a kill switch.
HDRider
Postby HDRider » 25 Jan 2015 12:58
The Roadster Factory sells new replacements that are identical to the original.
Edward Hamer
Petaluma CA
Postby busheytrader » 25 Jan 2015 16:50
Some motor factors or online suppliers particularly those supplying kit car type parts make up cables with crimped ends. Just tell them the length and spec etc and they'll crimp whatever connectors you need on to the ends.
The one I've used in the past closed down otherwise I'd post their details up. I think they used a hydraulic workshop press as they've never come loose.
1powerrack
Postby 1powerrack » 25 Jan 2015 18:02
Dave,
the crimped connector can be undone quite easily, with a fine screw driver, done many of these, then you can re crimp and or solder the connector when on the new cable
Dave Dyer
Postby Dave Dyer » 28 Jan 2015 14:16
Thanks Chaps for your replies,
Right I've removed the crimped connector from the battery lead,
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by 1powerrack</i>
Dave,
Which as you said came off easily. I'm going to solder it back on to my lead, but if this doesn't work, then John your idea is plan B!
Thanks,
Dave
